Alt wiring
trying to convert to a 1 wire Alt in my 68 does it matter where i tie into the circut with the red wire? What becomes of the brown wire? Any help would be great i want to start pulling some new wires.
![]() Last edited by cpisani70@aol.com; 11-08-2010 at 10:07 AM. |
![]() Join Date: Sep 2010
Re: Alt wiring
I just folded up the original alt harness and taped it up near the drivers headlight. Ran a 10 gauge wire from new alt to battery voltage terminal on the right fender
Posted via Mobile Device |
Re: Alt wiring
There are some good threads on the site about how to wire the 1 wire alt.
It is best to go with the 3-wire setup, but thats your call. |
Re: Alt wiring
I am being told this on the Edelbrock site also but no one will tell me why My computer for the fuel injection reads 13.1 volts with the one wire but only reads 12.4 with the three wire and I get a low voltage alarm. Why is the one wire bad.
69 Chevy 4x4 383 Power ![]() |
Re: Alt wiring
When you taped up the old wires and ran the new wire did the factory gauge still work???
Re: Alt wiring
Yes. It just reads voltage. If you had a light instead of a gauge it may be mor complicated.
Re: Alt wiring
A volt meter will work. The factory ampmeter will not.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#8 | |
Re: Alt wiring
How did you wire your 3 wire alt? Did you do just jumper a wire from the output terminal to the votlage sence input? Or did you keep the factory wiring intact? If you did the short jumper, you will get low voltage elsewhere in the system. The voltage sence reads the voltage AT the alt and reducese the output to maintain 13 ~14vdc right there. No voltage drop is accounted for. Several feet of wire later, the wire resistance has dropped the voltage too low for your system. The factory wiring had a "remote" votage sencing wire tied into the system several feet and some load away from the alt. Now the alt pumps up the voltage to account for voltage drop and you can read proper voltage all the way to your computer. A 1 wire alt just blasts high voltage regaurdless of the load. It looks good at first, but it can do bad things like cooking the battery, and not charging at all at idle. Fixitp has a nice write up some where around here.
#9 | |
Re: Alt wiring
Re: Alt wiring
So the factory gauge says battery does that guage read volts bercause it would be nice if having it work was that simple.
Re: Alt wiring
The factory gauge on my 69 is a amp gauge it shows charge or discharge A Volt gauge will show volts like 11,12,13,14. They had a special resistance wire to go through the factory amp gauge. I've been told you can't make it work with the three wire but I really don't know.
#12 | |
Re: Alt wiring
