Old 09-14-2010, 12:45 AM   #51
billsbowtie
billsbowtie's Avatar
Re: parting out a 68 lwb 4wd 4 speed truck.
harold here is a pic of the fuse block. not sure yet if buyer of cab wants it with cab or not.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 09-14-2010, 12:46 AM   #52
billsbowtie
Old 09-14-2010, 12:47 AM   #53
billsbowtie
heres a pic. of the dash
Old 09-14-2010, 12:54 AM   #54
billsbowtie
truck came from ca it's been in tn sence 95 it's been stored inside most of that time,
cab looks to me like it still has orig inner & outer rockers & cab corners these all need a little att. as useal in these olaces but not bad. worst rust i saw is where rocker meets the floor ft toward kick panel very fixable both ft cab suports are just starting to show rust not bad & i saw 1 spot on drivers side firewall about a couple "'s in size. around windshield still has shiney white paint on it no rust.
Old 09-14-2010, 08:35 AM   #55
bguild
bguild's Avatar
Originally Posted by billsbowtie View Post
bguild $65.00 shipped for everything except fender elms. they are pealing.
I think I am out on this stuff because I found most of it locally.. Thanks for looking into it though.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 09-14-2010, 03:03 PM   #56
69STEP350
do you have ac compresser
69STEP350 is offline   Reply With Quote
Old 09-14-2010, 03:38 PM   #57
billsbowtie
69step350 i have at least 1 for $25.00 but shipping would be at least $30.00 because its so heavy. i am not sure its good or not. i sale them for $25.00 to people to use for cores . core charges most places are $100.00.
Old 09-15-2010, 11:31 AM   #58
billsbowtie
don these plates & bolts are a little larger than your measurements they must be 3/4 ton stuff.
Old 09-15-2010, 11:43 AM   #59
67gmcstepside
Darn, are the plate holes wider then 2.5 inchs Bill?
Would you have the cooling fan available from this parts truck?
67gmcstepside is offline   Reply With Quote
Old 09-15-2010, 11:21 PM   #60
billsbowtie
plate holes are 3 1/4 ". i don't have a fan with this truck but i may have a 18" clutch fan i will check if that is what you are looking for. i have 1 elect. fan also.
Old 11-10-2010, 12:17 PM   #61
70BLAZERX2
bump ttt for you bill
someone is looking for a 4x4 frame.
70BLAZERX2 is offline   Reply With Quote
Old 11-10-2010, 12:24 PM   #62
billsbowtie
eric this truck has moved on. i am looking for a parts truck. i still have the burb for now.
