Old 06-17-2003, 02:09 PM   #1
Linus0014
Guest
Posts: n/a
brake lite still coming on
I just finished changing my rear drum brake shoes, cylinders, the drum itself and hardware. But my Brake lite on the dash still comes on. Why and how do I fix it?
Old 06-17-2003, 02:16 PM   #2
SEVEND2
SEVEND2's Avatar
is your brake fluid low? i did nt front brakes and it took about 30 min driving before the light went out
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 06-17-2003, 02:18 PM   #3
Linus0014
Guest
Posts: n/a
then again its always a good thing to bleed the brakes too, too tired and too damn hot:
Old 06-17-2003, 08:07 PM   #4
SEVEND2
SEVEND2's Avatar
I hear ya, 95 - 100 deg today, I am getting ready to change out my front calipers, they are gummed up
and stage 2
Old 06-17-2003, 09:20 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
Your dash brake light is still on because the the sensor in the proportioning valve hasn't centered yet. I found in the manual that it says to exert extra pedal presure and it will center and the light will go out. It could also just be full of crud/rust and not want to move like it should.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-17-2003, 09:38 PM   #6
Class of 69
Class of 69's Avatar
To help persuade it to move, have another person apply light pedal pressure, and then crack the brake lines loose one at a time AFTER the prop valve until the light goes out.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
