11-09-2010, 01:28 AM | #1 |
Carb cleaner and sickness
have ant of you guys got sick after using carb cleaner out of a can? i used some and the next day i was aching and sore and had a terible headache and no appitiete. has this happened to any of you?
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
11-09-2010, 01:31 AM | #2 |
Re: Carb cleaner and sickness
I used tons of carb medic when I was trying to diagnose an issue I was having, turns out it was the needle and seat, but no I never had an issue. I imagine if you had accidentally got it on you, or inhaled it directly it could make you sick, but just blasting it into a carb or cleaning up some metal shouldn't.
Trevor "You already said spite" |
11-09-2010, 01:32 AM | #3 |
i used a can of it in a garage cleaning out a carb
11-09-2010, 01:37 AM | #4 |
Did a quick search on the Carb Medic I used and found an MSDS sheet. It says that ""Inhalation: High concentrations of vapors may irritate nose and throat and cause symptoms of intoxication such as dizziness, nausea, headache,
or indigestion". Sounds similar to what you have, and the cure: "Inhalation: Remove to fresh air. If breathing becomes difficult give oxygen and get prompt medical attention. If breathing stops, give artificial respiration and get prompt medical attention." Reference MSDS: http://www.gunk.com/msds/M4814.pdf So unless you start having trouble breathing, I imagine it will clear up in a day or two, but you could always hit a walk in clinic and see if there is anything else you should do, no one likes those "too little too late" cases.
11-09-2010, 01:46 AM | #5 |
Don't use it if you are operating a space heater or any open flame heat in the area the vapors and the open flame supposebly turn into phosgene gas im told.
11-09-2010, 01:54 AM | #6 |
Phosgene from carb cleaner? That would make your exhaust extremely harmful, I read recently that Brake Fluid was the more likely source for Phosgene gas. Could be both though!
11-09-2010, 06:58 AM | #7 |
its all about the +6 inches
if you were using it PROPERLY and you got this reaction, then I would plan on never using the stuff again.
11-09-2010, 08:25 AM | #8 |
a little common sence when using stuff for cleaning that gives of vapors goes along way in keeping a body safe
11-09-2010, 09:31 AM | #9 | |
The Older Generation
That would be brake cleaner, and as far as I know only when you are using a wire welder with Argon and welding on parts cleaned with brake cleaner. LockDoc
11-09-2010, 09:44 AM | #10 |
Its a Truck Thing......
The MSDS (Material Safety Data Sheet) is the key to ensure your safety, but most people are unaware that it exists. Make sure you find it and check to see if there is any information that you need to for health reasons due to exposure and sickness.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-09-2010, 10:55 AM | #11 |
ive never gotten sick but i have destroyed my smell/taste with carb cleaner and many other chemicals as a bike tech.... it has to be a odd smell/different smell/STRONG smell for me to really smell it. there are lots of deadly chemicals in all these cleaners and we as humans just breath away without a second thought...
11-09-2010, 03:00 PM | #12 |
My Carbon Footprint
Well ventilated area!!!!!
I use tttttttons of the stuff and dddddddon't feel a tttttthing!! Actually, I do buy it by the case and only use it outside. It is nasty stuff. Last edited by prostreetC-10; 11-09-2010 at 03:07 PM. |
11-10-2010, 07:45 PM | #13 |
were you smoking while using it? I ask because smoking a cig/cigar that has residual chemicals on them will also cause issues.
11-10-2010, 08:05 PM | #14 |
NEVER use a torch close to break cleaner!!! tiny puff of smoke will just about kill you literally.
(different stuff but just saying |
11-10-2010, 10:03 PM | #15 |
My Carbon Footprint
You also should not strike a match while in your TNT storage shed!!! lol
11-11-2010, 01:18 AM | #16 |
60-66 Nut
That is very true with the chlorinated brake cleaner.
