06-17-2003, 04:55 PM | #1 |
my turn signals don`t go off!!!
the turnsignal in my blazer won`t automaticly turn off when i turn.
any suggestions on whats wrong??? thanks
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
06-17-2003, 04:57 PM | #2 |
If the lever doesn't return, then the problem is usually missing cancelling springs -- they tend to go :sprong:. These are cheap at NAPA and places, and are easy to replace once you pop the steering wheel off.
Brian |
06-17-2003, 05:00 PM | #3 |
Glowing since 1978
I believe your problem is your cancelling cam in the turn signal switch. You'll have to pull the steering wheel and horn button to gain access to the assembly. Then you should be able to see the action of the turn signal switch and determine if you need to buy a new assembly.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
06-17-2003, 05:08 PM | #4 |
its all about the +6 inches
Jamie, let me know if you need springs once you look into it. I'll send you a couple.
06-17-2003, 10:35 PM | #5 |
thanks guys!!!
i won`t get to look at till the weekend,at least now i don`t think it is nothing major.. btw thanks longhorn i`ll let you know.
