11-10-2010, 07:39 PM | #1 |
Airbags On A G-body
When installing airbags on a g-body frame do you have to use a spacer between the airbag and the upper frame? Also how much of a spacer do you need?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 Last edited by Fat Mike; 11-10-2010 at 08:01 PM. |
11-10-2010, 09:36 PM | #2 |
Re: Airbags On A G-body
Mike search for, My Project 56 chevy 1300. He gives a real good writeup on his project. I followed alot of the things he did and it worked out great. Good luck!
11-10-2010, 10:12 PM | #3 | |
Are you talking about the front or the rear? G-body kit was purchased from Air ride. I can measure the spacers if you indicate which ones you were referring to. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-10-2010, 10:54 PM | #4 |
I am referring to the front bags and I am using firestone 2600. I know you have to trim the housing out and make sure that the bag does not rub but I think the part I am talking about is the airbag upper cup.
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
11-11-2010, 09:48 AM | #5 | |
Thanks Marc
11-11-2010, 09:55 AM | #6 |
I found out that they are 4" and they did give dimension on them. With the help of Thomas at Aftershock Customs, alocal shop, we built are own.
11-11-2010, 10:18 AM | #7 |
I made a pretty good guess, since it has been quite sometime since I saw mine out.
They look pretty easy to make once you know what size to make them. Good luck Marc
11-11-2010, 11:01 AM | #8 |
Thank you very much for the info!
