Old 11-11-2010, 11:29 AM   #1
Agent915
Crossmember question.
I was wondering if the 73-87 crossmember/suspension is a direct bolt-in to the 67-72 C-10 frame? Seems that would be a cost efficient way to get 5 lug/disk brake set up. Also, is one wider than the other?
Danny
Agent915 is offline   Reply With Quote
Old 11-11-2010, 12:33 PM   #2
Tony@AirRideTech
Junior Member
Re: Crossmember question.
yes.... you can also just change ball joints,spindles and tie rod ends too..... or take the control arms off the donor along with the spindles and tie rod ends.... its all interchangable...
Tony@AirRideTech is offline   Reply With Quote
Old 11-11-2010, 01:02 PM   #3
tech@scottshotrods
What this dingle berry just said :-)
tech@scottshotrods is offline   Reply With Quote
Old 11-11-2010, 02:55 PM   #4
Agent915
Thanks!!
