Old 11-10-2010, 11:17 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Rear axle swap question
I have a friend building a 70 1/2 ton burb and wanting to go with the 5 lug set up. On the 12 bolt rear end, it looks to be the later, wider one. I am parting a 72 and wanted to know if just the axle shafts will interchange to that rear. Basically slide the shafts out of one to the other. Or will it be easier just to swap the complete rear end? Thanks for any input. Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-10-2010, 11:43 PM   #2
MAK191
Re: Rear axle swap question
Yes, if you have the wider one you can swap the shafts. But there may be a good reasons to just swap the whole rear end like condition, gearing, posi, etc.
MAK191 is offline   Reply With Quote
Old 11-11-2010, 03:07 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Originally Posted by mak191 View Post
yes, if you have the wider one you can swap the shafts. But there may be a good reasons to just swap the whole rear end like condition, gearing, posi, etc.
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-11-2010, 06:28 PM   #4
too much stuff
Roadtrip!
Thanks for the replies. The burb is pretty clean from out of state, and the cheyenne is a rusty MN truck. Makes sense to just swap the axles if possible. Eric
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
