Old 11-12-2010, 01:52 PM   #1
Piece of Work
Cultural Infidel
Piece of Work's Avatar
alternator wiring ?
Somewhere in the past, a PO changed the alternator to a one wire internal regulator SI 10. I want to change this to a 94 amp SI 12 3 wire. I cannot find any of the original wiring from when it had an external voltage regulator. Where should I look to find the wire for the # 1 terminal? What color is it?
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 11-12-2010, 01:54 PM   #2
dmwphoto
dmwphoto's Avatar
Re: alternator wiring ?
See if it was taped back behind the driver's headlight. That wire will be red.
dmwphoto is offline   Reply With Quote
Old 11-12-2010, 02:19 PM   #3
Piece of Work
Cultural Infidel
I located the old voltage regulator. Plug has 4 wires going in. Looking down at it, the first 2 are cut and gone, the next one is red and I can't tell what color the bottom wire is, but they are both there. Also I found a red wire in the harness that is cut off. I don't know which wire to use.
posted via La-Z-Boy
-Mark
Old 11-12-2010, 02:51 PM   #4
fixit-p
fixit-p's Avatar
Here's a diagram which shows the wires jumped at the old reg plug if you trace the wires to the alternator the brown wire goes to #1 and the red goes to #2. Is this a gauge or idiot light dash?
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 11-12-2010, 04:50 PM   #5
Piece of Work
Cultural Infidel
idiot light. Thank you, it works now that I found the brown wire.
posted via La-Z-Boy
-Mark
