Old 11-12-2010, 10:10 PM   #1
tonypaul
tonypaul's Avatar
Couple new mods-
Getting closer and closer finishing up my truck from a frame up. I started back in April and hopefully finishing up during x-mas. Anyway here are a couple mods I did this week:
Installed my clear 12 bolt cover, my truck is real low so you more than likely wont see it unless you crawl under and look but I thought it was cool -Name:  truck11-12 101.jpg
Also installed this Aeroforce Interceptor Scan gauge. I had been searching for a scan tool and ran across this. It is so cool! It solved my speedo problem as well as gives me a continual scan of my 7.4L Vortec... Plus it looks perfect with the rest of my gauges! You can check it out at: http://www.aeroforcetech.com/products_interceptor.html
Sorry the pics are kinda bad-
More to come!
tonypaul is offline   Reply With Quote
Old 11-12-2010, 10:13 PM   #2
jondancer
Re: Couple new mods-
that clear cover is cool, never seen one
jondancer is offline   Reply With Quote
Old 11-12-2010, 10:41 PM   #3
notrailerqueens
notrailerqueens's Avatar
that thing looks sick dude!
Lindsey Rae
85' chevy long box, built by a girl!
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956
notrailerqueens is offline   Reply With Quote
Old 11-13-2010, 12:55 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I've never seen a clear cover either, makes checking fluid level a little easier!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-13-2010, 11:47 AM   #5
tonypaul
tonypaul's Avatar
Im going to try to drop a LED light down in the housing. I think I can go down the vent tube or through the side fill hole. Well thats the plan....
Old 11-13-2010, 12:38 PM   #6
big_al_71
big_al_71's Avatar
vERY COOL INDEED!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-13-2010, 01:09 PM   #7
65Short
What about the start/run switch? Which vehicle was it sourced from? Was it hard to install? Thanks, Jon
65Short is offline   Reply With Quote
Old 11-13-2010, 02:06 PM   #8
tonypaul
tonypaul's Avatar
The start/run switch came from a 2010 Hyundai Sonata, it wasnt to hard to wire. I had to figure out the wiring on my own cause I couldnt find a diagram online. I might could have gone to the Hyundai dealership and got it but I figured it out. A couple relays and 4 wires off the switch is all it took to get it working. I have it wired to my GPS alarm start mode. A button has to be pushed on the remote to turn on the start/stop button so it will work....Im so tired of wiring- and still not done. Im taking a break from wiring for awhile, trying to get some of the interior and exhaust done this weekend...
Old 04-06-2012, 01:10 PM   #9
blazerboy_4life
70Custom10
Where did you get that diff cover? I was thinking about doing one a while back but I didnt think anybody made anything like that. Looks sweet!
blazerboy_4life is offline   Reply With Quote
Old 04-07-2012, 12:07 AM   #10
Andy4639
Old member
Andy4639's Avatar
Cool Re: Couple new mods-
Just ordered me one for the 71. Thanks tonypaul,
for the info. I had always thought about one.
Here is the link for them.
They say there on clearance so you may want to order it pretty quickly.
http://www.shopatron.com/products/pr...er=8410/1526.0
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-07-2012, 10:26 AM   #11
MrSchaeferPants
MrSchaeferPants's Avatar
I'd like to see a video of the gears going from stopped, to driving speed with the clear cover Especially with an LED in it. It'd be cool until it splashes oil all over it and you couldn't see anything anymore, but it'd be fun to watch until then.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 04-11-2012, 07:20 PM   #12
Andy4639
Old member
Andy4639's Avatar
Well, when I get mine installed I'll put my Gro pro camera to use and we will see what it looks like if I can find a good mounting spot for it.
Old 04-11-2012, 09:54 PM   #13
Husker
Husker's Avatar
Nice. Looks great
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 04-11-2012, 10:10 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
looking forward to this
