Couple new mods-
Getting closer and closer finishing up my truck from a frame up. I started back in April and hopefully finishing up during x-mas. Anyway here are a couple mods I did this week:
Installed my clear 12 bolt cover, my truck is real low so you more than likely wont see it unless you crawl under and look but I thought it was cool - Also installed this Aeroforce Interceptor Scan gauge. I had been searching for a scan tool and ran across this. It is so cool! It solved my speedo problem as well as gives me a continual scan of my 7.4L Vortec... Plus it looks perfect with the rest of my gauges! You can check it out at: http://www.aeroforcetech.com/products_interceptor.html Sorry the pics are kinda bad- More to come! |
Re: Couple new mods-
that clear cover is cool, never seen one
Lindsey Rae 85' chevy long box, built by a girl! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956 |
Big Red - Now its a SWB!
I've never seen a clear cover either, makes checking fluid level a little easier!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Im going to try to drop a LED light down in the housing. I think I can go down the vent tube or through the side fill hole. Well thats the plan....
vERY COOL INDEED!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
What about the start/run switch? Which vehicle was it sourced from? Was it hard to install? Thanks, Jon
The start/run switch came from a 2010 Hyundai Sonata, it wasnt to hard to wire. I had to figure out the wiring on my own cause I couldnt find a diagram online. I might could have gone to the Hyundai dealership and got it but I figured it out. A couple relays and 4 wires off the switch is all it took to get it working. I have it wired to my GPS alarm start mode. A button has to be pushed on the remote to turn on the start/stop button so it will work....Im so tired of wiring- and still not done. Im taking a break from wiring for awhile, trying to get some of the interior and exhaust done this weekend...
70Custom10
Where did you get that diff cover? I was thinking about doing one a while back but I didnt think anybody made anything like that. Looks sweet!
Old member
Just ordered me one for the 71. Thanks tonypaul,
for the info. I had always thought about one. Here is the link for them. They say there on clearance so you may want to order it pretty quickly. ![]() ![]() http://www.shopatron.com/products/pr...er=8410/1526.0
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I'd like to see a video of the gears going from stopped, to driving speed with the clear cover
68 GMC C2500 - 305 V6 - 4spd |
Old member
Well, when I get mine installed I'll put my Gro pro camera to use and we will see what it looks like if I can find a good mounting spot for it.
Nice. Looks great
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#14 | |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
