Old 11-13-2010, 09:03 PM   #526
menace121978
menace121978's Avatar
Re: my 80 build
sounds good! i couldn't help but to watch him slam the door into something a few times
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-15-2010, 03:11 PM   #527
Puglia10
Re: my 80 build
where did you get those leaf spring bushings?
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 11-15-2010, 07:59 PM   #528
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
classic parts of America
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-15-2010, 08:43 PM   #529
nbpro
Re: my 80 build
cam sounds awesome. this thing is gonna be a beast.
nbpro is offline   Reply With Quote
Old 11-15-2010, 09:24 PM   #530
flamingbig10
6.0 powered square
Re: my 80 build
With my plans in performance parts it should be are real wild ride
Aaron
Old 11-16-2010, 12:37 AM   #531
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: my 80 build
"Wild ride"
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 11-16-2010, 01:58 AM   #532
flamingbig10
6.0 powered square
Re: my 80 build
well I ordered from summit a h3 oil pan kit, fuel line adapters, a/n fittings, poly mounts, and gauge adapters
Aaron
Old 11-16-2010, 09:13 PM   #533
flamingbig10
6.0 powered square
Re: my 80 build
the cam, push rods, and valve springs came today
Aaron
Old 11-16-2010, 09:18 PM   #534
nbpro
Re: my 80 build
sweet
Old 11-16-2010, 10:30 PM   #535
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 11-17-2010, 07:18 AM   #536
menace121978
Re: my 80 build
nice! little by little buddy!
"Dennis the Menace"
Old 11-17-2010, 09:35 AM   #537
flamingbig10
6.0 powered square
Re: my 80 build
thanks Dennis, but the parts sure do add up quickly.
Well I got good news all the parts I ordered should be here today or tomorrow and if I get some to help me with the cam, pushrods, and springs the week, I going trying and pick and junk 4l80 so I can mock every thing up since I plan on adding a 3200 stall converter an they cost nearly as much as a used 4l80 around here
Aaron
Old 11-18-2010, 01:48 AM   #538
flamingbig10
6.0 powered square
Re: my 80 build
the brake lines came today
Aaron
Old 11-18-2010, 02:02 AM   #539
nbpro
Re: my 80 build
Looking good man
Old 11-18-2010, 11:43 AM   #540
menace121978
Re: my 80 build
hey Aaron... just wanted to give you a little tip before you get too far along with those brake lines. stainless steel brake lines are a much harder metal than the regular steel lines. i used ss lines on the front system. THEY ALL LEAKED! the only lines that didn't leak were the factory lines that i re flared myself. once your truck is together it is a *itch to fix them and very frustrating when you buy pre bent lines that are already flared and ready to go and they leak like a sieve.
so here's the tip take them off and heat up the flare with a torch until its red hot and let cool. this softens up the metal just enough that the flare will conform with the union when its screwed together. and you wont have any leaks
i probably will never use pre bent stainless lines again after all the trouble i had but if i do i will be heating those babies up before i install them for sure!
"Dennis the Menace"
Old 11-18-2010, 02:59 PM   #541
JohnC
JohnC's Avatar
Re: my 80 build
Coming along man!
Great tid bit Dennis!
JohnC is offline   Reply With Quote
Old 11-18-2010, 09:00 PM   #542
flamingbig10
6.0 powered square
Re: my 80 build
well I went with the oem, my order was messed up and they called me to confirm my order but I guess they didn't here that I wanted s/s I guess it was a good thing
Aaron
Old 11-18-2010, 09:04 PM   #543
flamingbig10
6.0 powered square
Re: my 80 build
thanks guys, got the order from summit today I will get some pics after wile
Aaron
Old 11-19-2010, 01:32 AM   #544
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 11-19-2010, 03:15 AM   #545
nbpro
Re: my 80 build
Aaron this thing is coming along great man. it amazes me for someone of your age to have the knowledge and the talent you do. keep up the good work and of course, all the pics that you can upload.
Old 11-22-2010, 01:01 AM   #546
flamingbig10
6.0 powered square
Re: my 80 build
thanks
I got the cam pulled today
Aaron
Old 11-22-2010, 12:08 PM   #547
spudz
spudz's Avatar
Re: my 80 build
Is it just the pic or are the cam bearings worn bad?
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 11-22-2010, 10:56 PM   #548
flamingbig10
6.0 powered square
Re: my 80 build
its oil
Aaron
Old 11-29-2010, 10:13 PM   #549
flamingbig10
6.0 powered square
Re: my 80 build
slid in the cam today and picked up a ls2 timing chain from gm
Aaron
Old 11-30-2010, 01:21 AM   #550
flamingbig10
6.0 powered square
Re: my 80 build
ls2 chain on left, 6.0 chain on the right, the links are thinker on the ls2 chain
chain dampener
Aaron
