Old 11-14-2010, 02:03 AM   #1
LEEVON
Moderator
LEEVON's Avatar
need a shock that travels 8-16"
I'm accounting for about a 20 degree angle, don't want to go any more farther and hurt it's effectiveness.
I have several shocks for mock-up on my '51 but none have the right length and stroke. I've been looking around at shock specs and can't seem to find one that fit's my needs. It will have to travel at least from 8" collapsed to 16" extended. None of the shorter shocks seem to fit that bill.
BTW this is a rear shock on my F9000 airbag equipped, trailing arm '50 chevy.
Any ideas?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-14-2010, 04:59 AM   #2
raycow
Re: need a shock that travels 8-16"
If your setup requires 8" of travel, the shock is going to be longer than 8" collapsed. A possible fix would be to relocate the mounting points to permit a longer collapsed length or less overall travel (like mounting at an angle).
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-14-2010, 09:49 AM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Check out the "pre-runner" series from doestch tech. Thats what I'm running on the back for my f9000's.
http://www.doetsch-shocks.com/
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-14-2010, 10:08 AM   #4
LEEVON
Moderator
LEEVON's Avatar
Thanks, I'll check those out. I did a poor job of explaining the length, I measured from eye-to-eye collapsed and got 8", then raised the airbags and got 16", that's where the 8" travel comes from.
Old 11-14-2010, 06:18 PM   #5
cajundragger
yeah you need to find out how much stroke you need, so I guess would be 8", then just find the shortest shock from a similar sized vehicle that has that stroke. picking shocks is always a give and take ordeal.
NAPA has a great book where you can use attaching point styles, and lookup by lengths and strokes.
cajundragger is offline   Reply With Quote
Old 11-14-2010, 06:41 PM   #6
nhtc33d
This Monroe site was a huge help fo me when i was looking for shocks. Hope it helps. http://www.monroe.com/catalog/docume...engthSheet.pdf
nhtc33d is offline   Reply With Quote
Old 11-15-2010, 01:00 PM   #7
colin_havens
colin_havens's Avatar
That is what I did for the rear shocks on my 67 with a custom 4 link read suspension. I measured my collapsed and extended distances, and determined what ends I needed, and went to Monroe's website to find the part number I needed. A short trip to the parts store, and I was back home putting them in.
BTW, I ran the Sensatracs, and they ride great! Those paired with my dominator airbags and my truck rides better than my wifes Lexus, even with my low profile tires.
colin_havens is offline   Reply With Quote
Old 11-15-2010, 05:23 PM   #8
LEEVON
Moderator
LEEVON's Avatar
I looked through that chart first, my unique short length is the problem. There aren't any shocks that collapse that far and have any amount of stroke. Looks like I'm going to have to re-design a bit, if I can get a shock with a collapsed length of say 10-11", there are more selections that have the range of travel I need.
Old 11-16-2010, 01:53 PM   #9
smashingchuck
I had to to redesign my chock mounts for the same reason.
78 Build Thread
4Runner Build
