Old 11-13-2010, 08:07 PM   #1
Scott26
Scott26's Avatar
Question 86 gmc Defroster problem??
My defroster is not working.The Heater works good, but when i switch to defrost it still only comes out of the vents. I can manualy move the door by the lever and it will work.I dont know if im missing something or something with the vacuum but i cant get back to see with out taking my whole dash apart why its not opening by itself.
Scott26 is offline   Reply With Quote
Old 11-13-2010, 10:57 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 86 gmc Defroster problem??
if you have a non ac truck its run by cables not vacuum otherwise you need to chase down vacuum lines
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-14-2010, 12:26 AM   #3
Scott26
Scott26's Avatar
thank you
Old 11-14-2010, 09:30 AM   #4
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
I've had trouble with the defroster in a couple of squarebodies and it always ended up being a bad vacuum pot or rotted hose inside the heater/ac plenum. It's a pot on the top of the plenum that opens the door to move the air upwards. It's kind of a pain to pull things apart to get to them, but I'd bet that's your problem too.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 11-14-2010, 10:28 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
the one by the pedal is for floor to defrost,
the other is to vents or not
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-14-2010, 10:30 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
you can remove the air tube part in front of the glove box fairly ez
when the white piece breaks the vents wont turn off
in this pic mine is broken
John
Old 11-14-2010, 12:21 PM   #7
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
you can check to see if that pod thing is broken with a vaccum gauge... if you hook up a mityvac to it and pull vacuum and turn your vents on... if it doesnt actuate, its not a good pod. if it works you have a vacuum problem.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 11-14-2010, 12:49 PM   #8
Scott26
Scott26's Avatar
thank you helped alot!
1986 GMC Sierra Classic 4X4
Old 11-21-2014, 10:33 PM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
I had the same problem. It was the small hard plastic vacuum line coming out bu the heater box with some electrical wires. Hooked it to a vacuum source and all is well.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
