Help wiring harness
Looking for help.need some sort of wiring diagram asap to wire 84 blazer doors with electric windows and locks. going into a 79 pickup. really need help
deer hunting, fish catching, 4x4ing country boy |
Re: Help wiring harness
This is what I've got for PW and PL. The 12v+ connection just plugs into the fuse block. If you don't have the slot for this, or want to run a blade style fuse, just lenghten the wire and run it to the power block under the hood, or to the battery. Place the fuse holder as close to the battery as you can. Do some searching and you should be able to find more info. Good luck with the swap.
