Old 06-16-2003, 02:37 PM   #1
Custom 68
Custom 68's Avatar
new vs old Air Conditioning
Hello All, I am in the process of restoring my 68 currently it is in pieces with hopes of getting put back together. Anyway it has factory air and used to work I have tried to seal up the fittings but am sure they got stuff inside anyway. At this point am I better off to convert this to R134 and use my old compressor. What are the ideas for changing the compressor can I just change this and what to use. I do remember there is a valve toward the box that would sometimes stick, if I tapped it it would get cool again. I have seen some posts saying the new ones are more efficient. My plans for the sake of money was just to use what I have (possibly a compressor change) but didn’t know what all to change if converting to the new R134.
Thanks and just wanted to see what others had done.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-16-2003, 03:57 PM   #2
1972ChevyGuy
1972ChevyGuy's Avatar
I personally like the old. Yes, 134 is cheap and easy to use, but in my truck it doesnt seem to blow as cold. You may have to have a dealers lisence to get the old freon? Depends on where you live i guess, but my vote goes to old style
1972ChevyGuy is offline   Reply With Quote
Old 06-16-2003, 04:33 PM   #3
crazy4chevs
crazy4chevs's Avatar
I second it.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 06-16-2003, 07:21 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
I third it, even if only to keep the market price for original stuff up whenever I get the cash to yank it all out and put in a Vintage Air system
Seriously, though, I can't stand the stock stuff...it's one big headache. As soon as I can I'm ditching it.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-16-2003, 08:36 PM   #5
1972ChevyGuy
The old is R12 right?
Old 06-16-2003, 09:52 PM   #6
Custom 68
Custom 68's Avatar
Yes the old R12 so would you just keep everything stock? I guess just a compressor change is out of the question. Does everything else need to be changed?
Dave
Dave
Old 06-17-2003, 11:45 AM   #7
1972ChevyGuy
When i changed a car over from 12, all I did was bleed off the R12, bought some yellow jacket gauges, and put in the new 134. Oil charge, leak sealant and the freon itsself. Has worked fine for 3 years now.
Old 06-17-2003, 11:50 AM   #8
1972ChevyGuy
bleh, it came up twice
Old 06-17-2003, 11:59 AM   #9
crazy4chevs
orfice tube (filter), reciver/drier, flush out the system,change the compressor if needed(pouring new oil in compressor), pull vac on system, recharge with r-12.
Note: some people put a kit in that changes the system so that it cycles instead of the compressor constantily running,this should be done with the system evacuated.
Old 06-17-2003, 09:27 PM   #10
fishuntr
If I can add a question..my 72 has an underdash system. It was installed at the dealer when truck was new, but is not factory air. It has a York compressor. Other than checking/changing the mineral oil in the compressor, does any additional oil have to be added in the system? Thanks
fishuntr is offline   Reply With Quote
Old 06-17-2003, 09:36 PM   #11
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
anywhere in the US to legally buy R12 you MUST have a license to buy it, and dont forget R12 (around here anyway) it cost between $35-$45 for a 12oz can (& keeps going UP)which aint cheap compared to about $4-5 a can for 134A....joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 06-18-2003, 02:32 PM   #12
garthdader
If you want to change to R134 then I would suggest the kit POA update kit from classicindustries.com. It is a POA valve deletion kit and it comes with all you need to convert to R134 except the compressor and evaporator. Kits runs at $325
garthdader is offline   Reply With Quote
