Old 09-25-2010, 02:03 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Fuel pressure goes from 55 to zero.
00 Z71, 5.3L w/126K.
A couple weeks ago the truck started to not start on the first hit. It was totally random when it did it, sometimes when it sat for a day or two, sometimes right after I just drove it, ect, but it would also sometimes kick right off in the same scenarios.
I put a fuel pressure gauge on the truck today. With the key on, the pressure gets up to what I'm guessing is around 55psi because by the time I get back around the hood to see the gauge it QUICKLY falls to about 20, I haven't waited for it to go to zero, but it starts falling really slow after around 20. I pushed the release valve on my gauge and repeated this several times.
So, is this a fuel pressure regulator or am I looking at a new pump? Does the regulator maintain pressure or hold it back from the pump (keeping it constant)?
Supposedly, a sign of a bad regulator is gas in the vacuum line. Mine is completely clean/dry.
Also, while running, pressure bounces from 54 to 56.
I just did the fuel pump on my s10, am I in for more fuel pump fun?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-25-2010, 09:04 PM   #2
clinebarger
Re: Fuel pressure goes from 55 to zero.
Bad check valve in the fuel pump. Yes, more fuel pump fun.
If your bed is empty, Remove it to get to the fuel pump.
clinebarger is offline   Reply With Quote
Old 09-25-2010, 10:06 PM   #3
67ChevyRedneck
I 99% figured it was the damn pump.
Jesse James
Project "On a Dime"
Old 09-25-2010, 11:19 PM   #4
67ChevyRedneck
New issue. Went to order new pump, apparently there's 2 versions for VIN T:
1999-2003 CHEVROLET SILVERADO 1500 5.3 VIN T w/o Evap Emissions Sensor Stamped TCU
1999-2003 CHEVROLET SILVERADO 1500 5.3 VIN T w/ Evap Emissions Sensor Stamped TCU
Ummmmm, any insight on this?
Jesse James
Project "On a Dime"
Old 09-26-2010, 07:18 AM   #5
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Buy whichever is cheaper. One has a little EVAP pressure sensor on it and the other doesn’t. If you truck requires the EVAP sensor just finish drilling the hole template in top of the new fuel module and move your old sensor over to it. Usually the fuel modules without the sensors are cheaper. I just did this on my ’04 Hoe.
Here is the pressure sensor that will be on top of the EVAP fuel module. It is basically the same sensor as a MAP sensor…..It just senses pressure inside the tank. These sensors seldom fail so I would feel comfortable using the old one to save a few bucks.
AC Delco 213-4429
DirtyLarry is offline   Reply With Quote
Old 09-26-2010, 11:09 AM   #6
67ChevyRedneck
Cool. The seller answered me back. If it says federal emissions it doesn't have it, if it says evap emissions (california requirement, maybe?) it has it. Mine says federal. If he's wrong, or I read the wrong thing, it's good to know I can fix it.
Jesse James
Project "On a Dime"
Old 09-26-2010, 11:11 AM   #7
truckdude239
truckdude239's Avatar
i would not cheap on on these pumps order an ac delco pump i've seen way to many after markets fail with 6 months to a year . and ac delco being the only ones to last
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-26-2010, 11:12 AM   #8
truckdude239
btw you can get the vin and call the dealer they will tell you which one u need
David fuller
2000 Tahoe 5.3l 378
Old 09-26-2010, 11:45 AM   #9
Boog
laying low
Boog's Avatar
Sounds like I have the same issue with my 00 Z71. It seems to run fine except the first start of the day or numerous times a day. Hit the key and it fires but dies immediately. Hit the key again and it spins over a lot like it is flooded or something. It does seem to idle slower than it used to. I have not checked the fuel pressure yet. Isn't operating pressure supposed to be around 65 psi?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-26-2010, 01:53 PM   #10
67ChevyRedneck
ac delco or delphi?
The delphi's are about $50 more. I just put a delphi in my S10. I think the delcos are made by delphi.
Jesse James
Project "On a Dime"
Old 10-01-2010, 04:56 PM   #11
Legend56BC
Legend56BC's Avatar
Exclamation Re: Fuel pressure goes from 55 to zero.
I will agree 100% with the above statement!!! I have a aftermarket one here on my shelf for emergency only I wouldn't even put it on craiglist to sell to someone...
Legend56BC is offline   Reply With Quote
Old 10-01-2010, 09:13 PM   #12
67ChevyRedneck
Don't worry fellas. Waiting on my order from GM parts direct.
I've read about the same issues on S10forum.com and GM-Trucks.com. Some lasted as little as 3-6 months!
Jesse James
Project "On a Dime"
Old 10-01-2010, 10:02 PM   #13
truckdude239
good old flow Chevy gmc dealer i deal with the dealer thats runs gm parts direct. good guys over there
David fuller
2000 Tahoe 5.3l 378
Old 10-02-2010, 10:40 AM   #14
67ChevyRedneck
Yeah, I sent them my VIN on tues night and they answered early wed morning.
Jesse James
Project "On a Dime"
Old 11-10-2010, 12:45 PM   #15
Boog
laying low
Boog's Avatar
How about an update Jesse.
Boog
primer is finer
Old 11-15-2010, 09:44 PM   #16
67ChevyRedneck
Ummmmmmmmmmmmm, still haven't fixed it
Been busy with work, house, s10 needed some lovin, and now that we have spending cash, been having some fun going out on the weekends finally!!!
I've been driving my S10 everywhere. The truck was hooked to the boat for a couple weeks, my tarp got a hole and I had to air/dry the boat out so I moved it around every couple days to the sunny areas of the yard so I didn't kill my grass. So she still got a little exercise.
I bought the pump like 5 weeks ago??? Just drove it to wally mart and back. Weird how it seems nothing is wrong. If it's nice this weekend I may finally get it done. Trying to get the gas as low as possible, it's down to 1/8 tank now, but that's still like 6-8 ish gallons. I do miss driving it. I used to drive S10 to work and Z71 on the weekends.
Jesse James
Project "On a Dime"
Old 11-15-2010, 10:07 PM   #17
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I've been having intermittent pump problems on mine too. Dropping the tank isn't alot of fun, but I'm getting better at it! I've had the tank out 4 times in the last month and now I can have the pump out in 20 minutes (if the level is low enough that I don't have to siphon gas out). My problem is that against advice on here I replaced the bad factory pump with a cheapy pump only (not module) and I'm getting a bad connection on the plug that attaches to the pump. So I pull it out clean connection, put some dielectric grease on it, put it back together and it runs good for week or so then dies. If it dies again I'm gonna bite the bullet and get a Delphi. Sorry for the long post but just sayin you made the right choice getting the oe pump.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-16-2010, 10:47 PM   #18
Boog
laying low
Boog's Avatar
Jesse I know you have already checked the vacumn line to the fpr for gas but I had done so also but it was after the truck sitting over night and mine was dry. The gas had drained back and the line was dry. This past Saturday I pulled the line just after shutting it off and gas poured out of it. By my post below you see I replaced the fpr curing my hard start problem. Way easy. 5 minute job for less than $50. It's back to it's old self again.
Maybe run yours a bit then shut it off and pull the line again.
Boog
primer is finer
Old 11-16-2010, 11:57 PM   #19
67ChevyRedneck
Thanks, I'll check that too. I already got the pump and I guess for a GMT800 it's overdue for a new pump anyway. Going to NY in about a month, don't want to be on the side of the road in the mountains of WV in December.... I'll do another pressure test with the new pump on and check the regulator after I've run it for a while too What's funny, is the last 9 or 10 times I've started it, it's been fine (starting on first hit)
Jesse James
Project "On a Dime"
Old 11-27-2010, 07:23 PM   #20
67ChevyRedneck
I finally fixed the damn thing. What a pain in the ass... Pressure is now holding.
I freaked myself out. After I got it done, I put the tank up in and left everything loose for a test. Turned the key and nada... no ZZZZZZZZZZZZZZZZZZZZZZZZ, crap. Started checking and swapping fuses... nada... put on my old thinking cap. Nada Started looking under truck and I see fuel filler ground wire hanging down... ah ha! The fuel pump ground and filler ground are on the same bolt and I had to loosen it to get the filler neck off! Tightened it down and it fired right up.
Jesse James
Project "On a Dime"
Old 11-27-2010, 09:13 PM   #21
Boog
laying low
Boog's Avatar
Well good deal Jesse. Be glad you put in an AC unit.
Boog
primer is finer
Old 11-27-2010, 10:09 PM   #22
67ChevyRedneck
Me too, there's no way in hell I want to do that again!
Jesse James
Project "On a Dime"
