Old 11-16-2010, 06:18 PM   #1
SiCk_DiAbLo
SiCk_DiAbLo's Avatar
Old Gas??
What's the best way to clean that old funky gas outta the carb and tank, it 's been sitting awhile and it reeks!!!
1993 Chevy Silverado.
1984 Chevy Z28.
1972 Chevy Custom 10.
1965 Custom 10..FOR SALE
SiCk_DiAbLo is offline   Reply With Quote
Old 11-16-2010, 06:34 PM   #2
Turkey
Turkey's Avatar
Re: Old Gas??
step on the pedal!!
Turkey is offline   Reply With Quote
Old 11-16-2010, 08:00 PM   #3
SiCk_DiAbLo
Re: Old Gas??
I tried that, but it just keeps mess'n the carb up...Had it apart a few times already!
1984 Chevy Z28.
Old 11-16-2010, 08:22 PM   #4
Indian113
Indian113's Avatar
Re: Old Gas??
Drain the tank,there should be a drain on your carb too. If not loosen the bowl on it.
Indian113 is offline   Reply With Quote
Old 11-17-2010, 01:37 AM   #5
KIC
1960 GMC Burb
KIC's Avatar
Re: Old Gas??
Run some SeaFoam ( $10.00/can) through it once you clean it out.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 11-17-2010, 02:24 AM   #6
Youngbuck7072
Youngbuck7072's Avatar
Re: Old Gas??
take the carb off and clean it out real good/ rebuild it. then take the tank out and clean it with a 1/4 mix of muratic acid and water, here is the thread on how to do it :http://67-72chevytrucks.com/vboard/s...d.php?t=430030
then, put the tank back in, and put five gallons of premium in it, and put a bottle over the fuel line where the carb would hook up to. turn the truck on but not over(this will cause your pump to run, and clean out the lines). then change all the filters out, and hook the carb back up and your good to go. this is what i did to my truck so i know it works, just make sure you get all the water out of the tank.
........................ __
............._______|__\____
............|_({})______({})]
................(O)..........(O)
Youngbuck7072 is offline   Reply With Quote
Old 11-17-2010, 03:21 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Old Gas??
Originally Posted by Turkey View Post
step on the pedal!!
Hell yeah!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-17-2010, 03:56 PM   #8
slepysal
slepysal's Avatar
Re: Old Gas??
x2 it will smoke like crazy but works fine
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
