#1076 |
Re: What did you do to your truck today!
Drove to work today; yesterday took my daughter fishing in it...
#1077 |
Simple? What's simple?
![]() Join Date: Apr 2007
Used it as a truck!
![]() Been my daily driver all this week - my regular driver is down for repairs.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#1078 |
Motor is ready to go back in.
#1079 |
Got the bed wood all channeled and fit. I think it will look pretty good when it's done. 3 coats of Pelucid(POR15) and then three coats of Helmsman Spar Urethane and she will be back on the road!
[IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1080 |
Been dinking with the qjet for months trying to get it to run right because I wanted to keep the truck original. Finally broke down and put a edelbrock on today kind of disapointing but it does run sweet.
Posted via Mobile Device |
#1081 |
RAT1968 '68 Cab/'71 Parts
Wanted to get to the shop to do some wiring. But I got a call from the polisher that the grill bezel was done. It was a wreck. $275 was steep, but what craftsmanship at Imperial Polishing in Fresno. Then, at almost the same time, I got a call back from a guy in Merced that was selling my new bench seat. Thanks, Armando. He said he knows you, Rene. In fact, I think he said that a part of my new seat was at your place at one time, and that you suggested the A****er Upholsterer that did the nice job.
The part on the seat is the Vintage Air firewall hose pass-through that I took to check the color compatibility. It's a Kirker color called Black Cherry Perarl. I am using it under the hood. But in the middle of the night last night, I woke up thinking about the painter/body work hassles I've had in the past. And the strange attitude and business sense that seems to want to attach itself to that artful profession. It drives me nutz. So, I'm going to paint the inside of the cab with this stuff myself, wait for the right body guy to do the body work and real paint outside. At least I'll have a truck to drive in the interim. I ordered another 6 qts of the Black Cherry. I did make it to the shop to confirm that the new lights/dizzy/horn harness was set up EXACTLY correctly. Another thumbs up to ECE.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#1082 |
yes, i do
Rewired my positive wire to my dizzy and put in a kill switch. Also pulled the passenger window regulator our and lubed the hell out of it. And found out that i need a front window chanel/wing window. Damn washington rust
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#1083 |
![]() ![]() Join Date: Jul 2002
Finishing up the work on welding up my front marker lights.
#1084 |
wow we have had some nice weather so I have been working a lot on it.moved the battery to the front frame,made a patch panel for left front rear fender,bought new left front fender and filled in side lite,finished caddy tail lights,went from tbi to carb set up,painted front frame.Ok that was not all today but over a week.
big old burb in primer.lot of work to do. |
#1085 |
Cut the frame and welded it up .Made my longbed into a shortbed
![]() Posted via Mobile Device |
#1086 |
![]() Join Date: Aug 2009
Didn't do much to my truck but I did go get another parts cab so i could both shorten my parts needed list and add parts to my for sale list...
#1087 |
I added some aftermarket guages to mine on Sunday and cleaned up some wiring and cleaned the engine bay a little.
It's not rust...It's character! |
#1088 |
dropped the transmission saturday, going to jbweld a drilled hole in the top today and put it back in tomorrow.
#1089 |
installed 100% fresh front and rear ends with a new 8" super lift and 3" body and sent my driveshaft in for extending.ordered some tweed for the door panels.woohoo
took from 5 a.m to 6 p.m for the axel swaps(trucks were immobilized,so it was done in a dirt driveway with plywood and one jack.) ![]()
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
#1090 |
More paint. We budgeted for paint and body work, but many other little parts broke the bank. I've done this before, so I should have known that it's always a heat-sink for dough.
Sometimes twenty bucks (fifty bucks... or three hundred bucks) at a time. So, some Kirker Black Cherry Ultra went on the interior earlier in the week. The paint's cheap.... and I guess it kind-of sucks. But Orchard supply hardware black epoxy primer first, then paint as soon as the primer flashes....Suck or not, it works well enough for the rat-rod for now. And there's a certain non-monetary pleasurable aspect to doing it myself. Today might be the last of the 70 degree days this year, so I sprayed the interior of the doors (they're off the cab and have had the body work done..NOT by me ![]() and a second shot around the windshield frame so I don't have to mask it up to the rubber when I finally DO shoot the outside. In the meantime, it's black primer on all the outside sheet metal, and Black Cherry "where the sun don't shine". Which reminds me, I also shot B.C. under the hood. A big day in the yard and shop.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 11-18-2010 at 01:38 AM. Reason: I'm lame |
#1091 |
Unfortunately, I sold my truck today. Well, technically yesterday. I hate when grown up priorities (buying a house) take precedence!!! Fortunately, the truck stayed in the family so I'll always know where to find it....
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
#1092 |
Project Heaven in my 67!!!
Checked on the status of my fuel cell made by fuelcellguy, should ship soon. Also, called about parts trucks that I bought and they should be resting at my workshop this weekend, thanks to my father and a good friend. Cant wait to get home on R&R and get some work done. Oh yeah, this week also ordered a rear disc brake conversion set for the new rear end and decided which rims will be outfitting Project Heaven in the near future... Shes coming along quiet well!
#1093 |
I ordered tie rod sleeves for my '69, needed the adapter sleeves to hook every thing up to the later model disc brakes that I put on it, those should about do it for parts to get it on the road, I'm excited about that, I'm ready to drive it.
#1094 |
SLOW POKE
![]() Join Date: Nov 2010
took the bed off the ole ' 68 . if the weather permits , i will start on the cab in the next few days
68 ![]() piece by piece ,
day by day , I will restore this truck , before the 100th anniversary !!! ![]() |
#1095 |
Took all the play out of my steering box by adjusting the set screw on top, put in new heater controls and at the same time fried my radio.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#1096 |
Cleaned up some heat shields gonna paint them tonight....and start masking off my stock air cleaner lid gonna try and spruce it up.
#1097 |
Still plays with trucks
Scored a set of complete doors, a new windshield and a tail gate for my recently acquired 69 C20 so it is now a complete truck.
Now all I need is the time to put the thing together and a place to do the work that is not out in the snow.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#1098 |
![]() Join Date: Aug 2007
Pulled it back home when it wouldn't run anymore.... foundout that my electric fuel pump had stopped working
#1099 | |
Some days are just more rough than others. I had a rough one today. It's all about paint. I sprayed the interior of the doors and left them in the "sun" all propped up and tacky on the back of the utility trailer. While I slept, the daughter and son-in-law's dog decided that the trailer was a good place to lick my paint. He licked, or rubbed, or whatever else, until he ruined the paint on both of them. Maybe it's a blessing of sorts, since the paint didn't lay down very well on the jams, anyway. Then, I fought with the steering wheel mod for a couple of hours. I think I've got that one....Now to figure out "how to" on the horn with that custom set up. Yesterday, when I did what I thought was the final mock up on the completed dash, I found a run down the upper-right side of the dash bezel. I sanded that today, and repainted it in gloss black...a nice contrast with the flat I used on the inside portion. I was happy with it. Until I mocked it up for the final-final. Yup! I found another earlier run that I missed the first time. I left the shop, came home and made a cup of coffee and took a nap. Tomorrow's another day.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 11-18-2010 at 11:26 PM. Reason: Don't know |
#1100 |
Sounds like yours was rougherer
