Old 11-19-2010, 08:39 AM   #1
jcloud6
How do I stop a Chrome Timing Chain cover leak
I had a oil leaks coming from the Oil Pan, Timing chain cover or the seal, so I purchased and replaced Oil Pan gasket with the 1 piece gasket, New Chrome Timing Chain cover with seal installed and a new Harmonic Balancer. All bolts were torque to specification. After the engine ran for a few minutes I notice a leak at the bottom of Chrome Timing Chain cover. What technique can be use to stop this leak, without replacing the Chrome Timing Chain cover? I Really need your help.
jcloud6 is offline   Reply With Quote
Old 11-19-2010, 08:55 AM   #2
baclay9
Re: How do I stop a Chrome Timing Chain cover leak
Might try pulling the timing chain cover and sanding the chrome off the mounting surfaces. Chrome accessories usually leak unless you do this IMO.
baclay9 is offline   Reply With Quote
Old 11-19-2010, 09:27 AM   #3
ont_guy_38
ont_guy_38's Avatar
The bottom rail where it meets the oil pan is not welded the whole length they are just spot welded so if you don't seal in on the inside with some sealer they will leak.plan on taking it off and sealing it or better yet take it off and throw it as far as you possibly can...lol...been through this
ont_guy_38 is offline   Reply With Quote
Old 11-19-2010, 10:59 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
bead blast the timing chain cover anywhere it contacts a gasket or throw it away and get a regular steel one.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-19-2010, 11:06 AM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I'm all for throwing it as well. Get a good OE one on there.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-19-2010, 12:01 PM   #6
sandnuriz
sandnuriz's Avatar
Yeah had to do the something chrome looks great but hates to seal up
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 11-19-2010, 12:25 PM   #7
camshaftgsxr
camshaftgsxr's Avatar
chrome wont get you home...
camshaftgsxr is offline   Reply With Quote
Old 11-19-2010, 04:40 PM   #8
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Dump the chrome. Been there-done that-learned a costly, time-consuming lesson.
78 Big10 454 is offline   Reply With Quote
Old 11-19-2010, 09:22 PM   #9
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
You sure it's from the timing cover and not the bolt area near the fuel pump? I would go for an OEM unit or a nice Milodon unit.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
