Old 11-20-2010, 12:25 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
Ignition Coil Overheating?
I use my truck to do deliveries at my place of work and I drive it a good bit in a day (lots of starts also). Every once in a while, the truck will not start and just turn over. When this happened tonight, I had my timing light with me. I hooked it up and no flash. I poured a cup of water over the coil (HEI) and then sprayed a little carb cleaner to dry it off. It started right up. It happened again later on and this time, it wouldnt start. I had to let it sit for an hour. What could be causing this? How can I keep this thing cool? The coil is only a month old and the last coil did the same thing.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-20-2010, 12:46 AM   #2
tim21391
tim21391's Avatar
Re: Ignition Coil Overheating?
my guess maybe too much power going to it?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-20-2010, 05:59 AM   #3
raycow
Is this a factory HEI with the coil in the cap?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-20-2010, 06:28 AM   #4
cdowns
cdowns's Avatar
if your not getting a full 12volts or you have a bad ground both can lead to overheating
Old 11-20-2010, 04:51 PM   #5
crm318
crm318's Avatar
What ground should I look for/clean? It is a factory style HEI.
1972 Cheyenne
Old 11-20-2010, 06:21 PM   #6
hayhauler71
hayhauler71's Avatar
some times there is a ground that is attached to one of the coil screws others have a ground strap under the coil that the coil sits on and is retained when the coil screws are tightened.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-20-2010, 09:21 PM   #7
OhOneWS6
OhOneWS6's Avatar
They all have a ground strap. Other wise it won't run. Even thought the distributor is grounded through the body of the distributor, the cap is plastic and insulates the coil from ground. If the ground strap is not there the circuit is not complete. it's something to check.
CRM, Did you run a new wire for the HEI or did you use the existing wire from the old points setup? If you used the old wire there is resistance built into it. You need to run a new wire for the HEI. Where are you getting the coils from?
OhOneWS6 is offline   Reply With Quote
Old 11-21-2010, 04:00 AM   #8
crm318
crm318's Avatar
OhoneWS6 Thank you for the visual. Yes, that is all in good order. When I got the truck, it had the original points distributor and ceramic insulator. i replaced it with a 12 gauge wire. Ill check the connections on it.
1972 Cheyenne
Old 11-21-2010, 01:54 PM   #9
crm318
crm318's Avatar
I got my coil from Oreillys.
1972 Cheyenne
Old 11-21-2010, 04:20 PM   #10
OhOneWS6
OhOneWS6's Avatar
Oreillys usually has decent quality parts. I've had issues with a lot of Auto Zone stuff. Usually things like starters and alternators. I'd also check to make sure the alternator is not putting out too much voltage. Where did the distributor come from?
Old 11-22-2010, 02:44 PM   #11
crm318
crm318's Avatar
The distributor is an aftermarket one that I bought brand new 7 years ago. The altenator is about 1/12 years old.
1972 Cheyenne
