Old 11-18-2010, 10:05 AM   #1
brans72
van tilt wiring adapter?
Where can I find a adapter to fit a van tilt to facorty wiring harness in our 67
C10 truck? The van connector is kinda half moon shaped and factory is flat type. Any help would be great. Brandon
brans72 is offline   Reply With Quote
Old 11-18-2010, 10:45 AM   #2
67cheby
67cheby
67cheby's Avatar
Re: van tilt wiring adapter?
you can get them from IDIDIT
67cheby is offline   Reply With Quote
Old 11-18-2010, 10:56 AM   #3
spike38
spike38's Avatar
http://www.ididitinc.com/index.html
if you can't find it on line, call them.
Spike
spike38 is offline   Reply With Quote
Old 11-19-2010, 08:20 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
dealer, less than 12 bucks
Old 11-19-2010, 08:51 PM   #5
bigdogboxers
bigdogboxers's Avatar
I found adapters in some 1971 and 1972 trucks... it was kinda random in the trucks i found them in. I bought a after market adapter from lmc and it didnt fit right so i pulled it back out then when i was looking for other parts i found the adapter in a automatic truck with a none tilt column. so if you just check around you should be able to find one. I am not allowed to sell on here but if you post a i want to buy add i bet a few members on here probably have some stashed away.... I will also check to see if i have any left.
bigdogboxers is offline   Reply With Quote
Old 11-19-2010, 10:39 PM   #6
brans72
And just what do you tell the deal you want/looking for?
Old 11-20-2010, 02:13 PM   #7
bigdogboxers
Thumbs up Re: van tilt wiring adapter?
I have only one of these left... like i said the one i bought from lmc (page 95 part number 36-0599) I tried to modify and still no worky....
Old 11-20-2010, 10:16 PM   #8
spike38
spike38's Avatar
CCP has them for $15
Spike
Old 11-20-2010, 11:33 PM   #9
bigdogboxers
Have you bought any from them? Do they fit properly? that would be the test....
Old 11-20-2010, 11:52 PM   #10
spike38
spike38's Avatar
True, But I'm wiring direct
Spike
