Old 11-21-2010, 01:58 AM   #1
tthornt
tthornt's Avatar
1983 c10 rearend
What's all. i just installed a 400 tranny behind my 283 small block.
my rear end is holding me back. i want better hywy mileage.
Which rearend shoul i install?
Thanking all in advance.
Country; LIKE A ROCK
All that I am, I owe
62SWB-STEP
83SWB
86LWB
tthornt is offline   Reply With Quote
Old 11-21-2010, 02:06 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1983 c10 rearend
What gear do you have now?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-21-2010, 02:14 AM   #3
454HO
If you are so concerned with gas mileage, why did you install a TH400? That is probably the worst transmission, other than a powerglide, as far as gas mileage is concerned. With a 283, you should have been looking for a 700r4 transmission. Better 1st gear ratio for performance plus an overdrive gear for mileage.
- Greg
454HO is offline   Reply With Quote
Old 11-21-2010, 05:41 AM   #4
GMC Guy
GMC Guy's Avatar
agreed.
your 283 paired with a 700r4 and running some 3.42 gears would definitely give you some decent gas mileage. (for a truck)
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 11-21-2010, 04:40 PM   #5
C-10 simplex
Also, it would be easier and cheaper to play with rear tire sizes and brands in order to get the right rpm for highway cruising.
Alum wheels and brake drums would also be beneficial.
C-10 simplex is offline   Reply With Quote
Old 11-22-2010, 12:06 AM   #6
tthornt
tthornt's Avatar
Thanks for the response. Intially i was running a th-350 (until it died on me). i couldn't afford to rebuild it right now. The th-375 is my stand-by tranny, so i decided to install the th-375. i'm not certain of which gears i have now, i do know it's a posi. I'm currently running a set of 255/60r-15.
Should i change the rear gears to 3:7x or lower and/or install another tranny or keep what i have?
Thanking your in advance.
62SWB-STEP
83SWB
86LWB
