11-21-2010, 08:22 PM | #1 |
People know me
Soft top mounting questions
Ok so I am planning on buying a new soft top later this winter. I am going to be shooting some als liner in the tub this thanksgiving weekend and am going to go up and over the bedrails of the blazer. It has the captured nuts in it for the singlewall top and was wondering if I would be screwing myself down the road if I weld the holes closed and bedline over the top of them.
Does the new soft top use any of these holes or do you have to drill your own?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
11-22-2010, 12:29 AM | #2 |
SKINNY TIRES RULE!
Re: Soft top mounting questions
My soft top uses the same mounting points as the hard top (STC Fastrack). The old Kayline I had on my 69 did the same.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-22-2010, 01:10 AM | #3 |
People know me
I am going to be installing a new soft topper. Does anyone know if they use all the captured nuts or just some of them? If it is just some of them can you let me know which ones?
I would really like to clean the top of the bedrail up.
11-22-2010, 02:11 AM | #4 |
Member #1049
My best top mounting hardware is drilled for both and uses either the single wall holes with the captured nuts or the double wall holes using bolts and nuts..
