Old 11-23-2010, 01:23 PM   #1
pushiniron
1987 R10 v6 conversion to v8
Has anyone converted a 4.3 v6 to a 350? if so what exactly had to be done to the motor mounts?
pushiniron is offline   Reply With Quote
Old 11-23-2010, 01:32 PM   #2
Clyde65
Clyde65's Avatar
Re: 1987 R10 v6 conversion to v8
since your doing that, why not go with an LS motor, youll be glad you did. The lsx will give you better power and more MPG than the 350, all you would need to do is update your intank fuel pump to a Walbro 255 and do some wiring changes. Do you have a 4 or 3 speed tranny?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-23-2010, 01:35 PM   #3
pushiniron
i have turbo 350
Old 11-23-2010, 09:19 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Motor mounts are the same.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-24-2010, 08:59 AM   #5
pushiniron
does the frame brakets have to be moved forward? I do know there's a difference in v8 brackets and v6 brackets.
Old 11-24-2010, 10:45 AM   #6
Clyde65
Clyde65's Avatar
the 4.3 is nothing but a 350 without the two extra cyl on the front, mounts should be the same along with all acces. mounts also.
I think you could do a 5.3l with under 100k miles for probably under $1k total. it would do much better mileage than a stock 350.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-24-2010, 10:59 AM   #7
pushiniron
thanks for the info. Its not stock.
Old 11-24-2010, 04:33 PM   #8
kevinr1970
Mounts are the same, "towers" are different.
But should be available in any 73-87 v8 truck.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
