Old 11-22-2010, 06:35 PM   #1
cam.man67
cam.man67's Avatar
parking brake not working
Title says it all. I just had my new trailing arms put on, the parking brake hooked up on both sides, but they don't work. I got under the truck, noticed there was a lot of play in the lines, tightened it up as far as I could, but they still don't work. When I press the parking brake pedal, I don't feel any force until I'm about halfway down, then it gets tight as it should. Having taken out the play underneath the truck, is there any place else I can tighten it up to get the ebrake working again?
thanks in advance!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 11-22-2010, 10:24 PM   #2
68anniversary
Re: parking brake not working
Did the cable come loose from the hooks? Just in front of the rearend connection there is a hook on either side to pull the cable over to the frame. If that's come loose you could have slack in the cable.
68anniversary is offline   Reply With Quote
Old 11-23-2010, 10:22 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
did you use the original parking cables from the truck???....There are LWB and SWB parking cables.....Also, i think I read somewhere that you need to depress the Pbrake about halfway down and then hook up the cables from under the truck....make sense?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-23-2010, 02:52 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
www.inlinetube.com has replacement brake cables, stainless or OEM-style.
Member Nr. 2770
Old 11-23-2010, 04:34 PM   #5
k2rm
k2rm's Avatar
Check inside the cab behind the parking brake mechanism. My cable housing was not secured so pushing the pedal would only pull the housing without pulling the cable. I fastened the housing to the firewall and my parking brake worked great afterwards.
k2rm is offline   Reply With Quote
