Old 11-23-2010, 11:22 AM   #1
RenoKeene
Florida Edition
RenoKeene's Avatar
Front sway bar bushings that don't squeak?
I've read alot about polyurethane front sway bar bushings squeaking. Rattles and squeaks make me crazy so.......Anybody used polygraphite bushings like Early Classic sells? How about pros and cons of stock type rubber? I'd like to do it RIGHT the first time.......no squeaks!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-23-2010, 11:45 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Front sway bar bushings that don't squeak?
Rubber bushings are just fine, but not as firm as Polygraphite. I recommend the polygraphite bushing instead.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-23-2010, 11:49 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
If you're using polyurethane, the grease you're using can make a difference in the squeaking...
http://www.spohn.net/shop/1982-1992-...4-oz-Tube.html
http://polybushings.com/pages/bushinglube.html
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-23-2010, 04:30 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Do the polygraphite bushings squeak? I'll lube whatever I put on but what is best for the long run? These big blocks are front HEAVY! I have a couple go-fast units for diving into those tight turns, this one's more for showin off. I just don't want it to squeak. Stock rubber would be fine but better is better.
Go fast units:
Super Late Model, Port City chassis, 358 9:1 Bush Cup motor "Mama Bear"
97 Z28 Last of the LT-1's "The Hornet"
Old 11-23-2010, 05:34 PM   #5
vin63
vin63's Avatar
In my experience they can and have...my Pontiac 455 and 4L80E trans combination is probably comparable in weight to your BBC, and I run polyurethane sway bar bushings with no squeaks using the lubes I listed.
Old 11-23-2010, 09:07 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Polygraphite is a compound comprised of urethane and impregnated with graphite particles. In theory it is self lubing, so it should never squeak. I ran a set on a Blazer I was building and they were very quite.
Articles-
"Refining Sierra"
Old 11-24-2010, 10:36 AM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Thanks to all for the info. I've learned more about these trucks on this forum in the past 2 weeks than I've learned on my own in the past 2 years.
Reno
Old 11-24-2010, 12:44 PM   #8
robnolimit
robnolimit's Avatar
It is a bit of extra work, but we drill into the swaybar mount strap and through the bushing, install a grease zerk, and use the correct lube. Dee Engineering now sells the mount straps drilled. Also, look for bushings that have ribs/grooves to hold the grease.
robnolimit is offline   Reply With Quote
