Old 11-24-2010, 02:54 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Throttle cable help please!
ok, We took the carb off in doing some maintinence to my truck, I thought we got everything how it was supposed to be. I had to have someone come and time my truck (sorry guys, I just didnt have the mental strength to attempt it) The guy said that we have the throttle mounted wrong. I have older pics of my carb, it looks like it is where it always has been. But this spring.... where in the heck does it go? I know it holds tension for the throttle. Does it look right otherwise... what am I doing wrong??
thanks so much!!
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 11-24-2010, 04:01 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Throttle cable help please!
It should connect to something towards the back. It's used to pull the throttle closed.
The solenoid in the picture for the A/C or is that part of the old emissions?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-24-2010, 04:13 PM   #3
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
are you talking about the thingie in the bottom left? looks like it has a white lable on it? Not sure, just took off all the after market AMA underdash set up I was talked into years ago,if its part of that then Ill take it off. Thanks for the help, Ill try to get it going now.
Old 11-24-2010, 04:22 PM   #4
Alex Hayley
You might try to connect the throttle cable to the upper hole in the carb linkage (for lack of a better word). The spring should be connected to a brace/bracket that is either mounted to the rear mounting bolt on the carb or to a bracket mounted to the intake manifold. I would take a picture but I changed the throttle linkage to a Lokar system.
Alex Hayley is offline   Reply With Quote
Old 11-24-2010, 04:35 PM   #5
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Thanks Alex. Does anyone have a pic they can share with me,something just dosent seem right, does the rest of it look like its right? Geeze, this is frustrating. thanks
Old 11-24-2010, 04:53 PM   #6
Sport/Truck
Sierra Grande Club
Here's a before and after.
The first picture is the original carb, the second is the SMI withe all the stock brackets.
Old 11-24-2010, 04:57 PM   #7
Sport/Truck
Sierra Grande Club
My solenoid was for the transmission controlled spark setup (or whatever it's called) but I think the solenoid was used for A/C units also.
s/t
Old 11-24-2010, 05:12 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Jodie,
Looks to me like these two brackets are wrong. The cable should be horizontal, like in Sport/Truck's pic, not angled...
LockDoc
Leon
Old 11-24-2010, 05:38 PM   #9
LONGHAIR
It looks like the right bracket, just mounted to the wrong place. It should be under the rear stud of the carburetor's base plate. That will put the return spring's mounting hole down where it belongs. Then the other end of the spring goes into a hole in the lower part of the throttle linkage.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-24-2010, 05:46 PM   #10
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
ok,,, it all comes together! Yes, now I see, we didnt mount that bracket on the BACK of the carb, I thought there was something that was supposed to go there, it was too clean. lol. I think we can get it with yalls pics and info. If not, Ill be back! lol
Thanks so much....again...
