Old 11-24-2010, 11:24 PM   #1
fortytwo
Where can i get axle mounts
Howdy,
I am looking for a set of axel mounts new for controll arm setup for my 67. I plan on lifting the truck by moving the axel to the bottom and i figure all i need are new mounts and new u bolts.
I have looked but i cant find them. also what are they officially called perches?
Ed
fortytwo is offline   Reply With Quote
Old 11-24-2010, 11:26 PM   #2
msgross
msgross's Avatar
Re: Where can i get axle mounts
spring perches for a solid axle?
http://www.ruffstuffspecialties.com/...wrap-c-14.html
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-25-2010, 12:18 AM   #3
fortytwo
Ya i am talking about the rear, trailing arms. Sorry my mistake.
Old 11-25-2010, 07:15 AM   #4
cdowns
cdowns's Avatar
you'd need to address the geometry of the panhard bar too// it should b as close to parrell to the axel as you can get it for proper operation
Old 11-25-2010, 09:48 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
CPP and ECE sells the weld on axle perches for trailing arms.
Keith
Convert to disc brakes.
Old 11-25-2010, 11:38 AM   #6
fortytwo
I never thought about this!! I guess i will just have to make a new upper mount, maby even just make a new bar while i am at it. I assume it should be horizontal when down with proper weight on it. Would a longer bar perform better? I can easily turn new ends and eve use steel tubing with a adjustible end and lock nut.
Ed
