Bagging the rear on a '71 C10
I have an idea on the front. Ive done some research on the rear, but have a few questions. Im not wanting it to lay frame or anything just low. Ive read where some are using the stock trailing arms. Do i just drill holes in the stock coil brackets? did you guys move your shocks? would i need to move the panhard bar? Thank you and Happy Thanksgiving!
Grandpa in the rustmobile...
Re: Bagging the rear on a '71 C10
id say an super trac bar shock relocators drop shocks and bags (pretty sure you make a bracket that bolts to trailing arm)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
you don't need a bracket ... bolt the bag where the coil spring was
