70 Chevy 1/2 ton 4 z4
Decided to change my 70 chevy over to front disk
used disk off a 74 got new master cylinder and booster for a 72 new from parts store Now the back brakes lock up when you barely touch the pedal changed master cyinder didnt help Gene Sharp ![]() |
![]() Join Date: Feb 2001
Re: 70 Chevy 1/2 ton 4 z4
You might get better assistance in this area. Good luck.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Perhaps a bad proportioning valve? If all the force is heading straight to the rear and not being dampened.
Trevor "You already said spite" |
did u change the prop valve
67-72 parts collector,…
![]() Join Date: Nov 2002
X2.
You have to swap out the drum brake "distribution block" for a disc brake proportioning valve.
