Power steering pump 64 230 inline 6
I'm puting power steering on the 64. It has a 230 inline 6. Will a set of brackets for a 75 and up 250 6 cylinder work to mount the pump?
Thanks... |
![]() Join Date: Apr 2001
Re: Power steering pump 64 230 inline 6
yup... but the 73-up used a long water pump that would require you to use the 250's pulleys too.....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
If the donor brackets are from an integral head motor they won't fit.
i just did what you want to do on a early 250 i put in a m715 jeep. i used the later brackets, water pump & pulleys but like geezer says the brackets don't fit. i cut them up & left the pump bracket on the pump but fabbed a new bracket from the head to reach the pump bracket & welded them together. i will take a pik for you & post it tomorrow.
andy |
If you are having trouble finding brackets, look at 6 cylinder cars. PS was more common on those than on the trucks. As already mentioned, stay away from the integral heads.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
ok here are the piks of what i did. you can see i cut the mount in two, then bolted a piece of flat to the head then bridged the gap. i run the adjusting arm from the alternator mount below. ain't fell off yet!
andy ![]() ![]() Last edited by andyh1956; 11-26-2010 at 12:44 PM. Reason: wrong photo |
Andy, that's not a bad setup at all.
Ray
it's worked good 'cept for one problem. i may have to re-mount the steering gear upside down. every time i fill the pump reservoir all the oil runs out the bottom of the gear!
