Old 11-26-2010, 07:59 PM   #5
67C10BUB
67C10BUB's Avatar
Re: Such highs and lows....
Originally Posted by tonypaul View Post
Its RUNS! I charged the battery over night and hooked it up this morning. Fired right up., but it has a little pop in the exhaust like a little back fire at idle. It revs good but at idle it has a soft pop to it. I didnt run it very long as its cold here today and I only opened the garage a little. Its running a little rich also. I figure if I can get it out of the garage and let it idle for a while and let the computer pull in the timing and fuel mixture it should be fine.... Im hoping it will be fine, Im getting so close to being done with this build.Gotta do my reverse light wiring, build my rear sub box, hook up my air compressor for airbags, get the front windshield put in... OH the brakes, gotta do the brake lines... Then final buff and put on the upper and lower trim and Im done!!! Still shooting to be finished on x-mas day....
Thanks for everyones suggestions and kind words...
Thank God. That is some good news. Hopefully I'll have the same luck after I get my injectors back from being cleaned.
67 5.3L Build
67C10BUB is offline   Reply With Quote
