Old 11-28-2010, 10:33 PM   #1
yote1234
yote1234's Avatar
help! truck wont start! help plz......
well after a 13 month total restorationon my 72 cheyenne i am trying to start it again.. but it wont start. can anyone think of something i missed?
its an hei system.......
pulled #1 plug
brought piston up to top of compression stroke
rotor pointing at #1 plug wire
plugs getting plenty of spark
poured gas into carb to prime
activate starter
nothing but turning over!
will not even hickup... any ideas?????
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 11-28-2010, 10:42 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: help! truck wont start! help plz......
Firing order right? 1-8-4-3-6-5-7-2? clockwise on the cap?
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-28-2010, 10:46 PM   #3
yote1234
yote1234's Avatar
yes sir! checked twice... clockways...
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-28-2010, 10:57 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Does it sound normal when it cranks over? Are the plugs dry or wet after cranking?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-28-2010, 11:01 PM   #5
yote1234
yote1234's Avatar
sounds very normal turning over.. just cranking... plug lightly moist with fuel... not bad?
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-28-2010, 11:04 PM   #6
hayhauler71
hayhauler71's Avatar
rocker arms adjusted to tight holding valves open. did you do a compression test?
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-28-2010, 11:07 PM   #7
yote1234
yote1234's Avatar
ahhhh!!!! no i didnt.. and i had the engine rebuilt someone else... will do a compression test tomorrow! big thanx...........
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-28-2010, 11:14 PM   #8
hayhauler71
if the engine sat for awhile the lifters may have bled down causing the valves not operate properly. cranking the engine over a few more times should pump them back up but do not flood the engine or you will wash the cylinders down
Fuzzy
Old 11-28-2010, 11:19 PM   #9
yote1234
yote1234's Avatar
hmmm. so you think i should start with compression test?
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-28-2010, 11:22 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
or go thru a complete rocker arm adjustment procedure for all valves.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-28-2010, 11:25 PM   #11
yote1234
yote1234's Avatar
yea might have to... i will call the guy that rebuilt it to see what he sayz as well. thx,guyz..........
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-28-2010, 11:26 PM   #12
hayhauler71
compression test will tell the story
Fuzzy
Old 11-28-2010, 11:39 PM   #13
rsavage
rsavage's Avatar
Make sure that you aren't 180 degrees off. It's easy to stab the distributor at what you think is TDC on compression when it actually was at the top of the exhaust stroke. You can pull the driver's side valve cover to insure both valves are closed, and you could also check to see if rockers are adjusted close at the same time.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-29-2010, 01:23 AM   #14
hardwaa
hardwaa's Avatar
Figure it out yet?
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 11-29-2010, 01:35 AM   #15
Nuts&bolts
Smile Re: help! truck wont start! help plz......
Hello every body I'm a newbee posting stuff I've had a problem like that on my last motor and it showed spark but the hei was not getting enough spark simple test run a wire stright from hei + to battery + just to ensure the right spark... Just a idea
Nuts&bolts is offline   Reply With Quote
Old 11-29-2010, 11:03 AM   #16
yote1234
yote1234's Avatar
i thought that but, it is on compression because we put our thumb over the plug hole and it pushes out.....
will check tonight. thx...
Originally Posted by hardwaa View Post
Figure it out yet?
not yet. i couldnt reply to your pm. its a setting at your end. ???
[QUOTE=Nuts&bolts;4319726]Hello every body I'm a newbee posting stuff I've had a problem like that on my last motor and it showed spark but the hei was not getting enough spark simple test run a wire stright from hei + to battery + just to ensure the right spark... Just a idea
i have 1/2 " of spark jump...?
so i dont think its that. but thx for the reply. and welcome to the site.....
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 11-30-2010, 08:36 PM   #17
yote1234
yote1234's Avatar
well i found out the problem........ dist hold down bolt loose! it was raised up off the block deck about 1/2 " and out of timing... i thank all of you for your advice!!!!!! big thanx............. dave
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 12-01-2010, 12:42 AM   #18
swamp rat
swamp rat's Avatar
I may be a little late but did you prime the oil pump before you started cranking? i read it was just rebuilt..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-01-2010, 12:51 AM   #19
doctrouble
doctrouble's Avatar
Wow, you guys are awesome , just the response time on replies, it's like an emergency room for my truck . Sorry this is my first post on the forum..
doctrouble is offline   Reply With Quote
Old 12-01-2010, 09:42 AM   #20
yote1234
yote1234's Avatar
yes sir i did... thx,dave
i agree... these people are g r e a t !!!!!!!!!! thx everyone !!!
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
