Old 11-30-2010, 12:50 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
factory oil cooler?
Has anyone have or seen a factory oil cooler? I have one and it seems to be factory. just never read anything here about factory oil coolers.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 11-30-2010, 01:03 AM   #2
83burban
Re: factory oil cooler?
I had one on my suburban before I swapped motors. They were a dealer add on option for our trucks - not a factory option.
Pretty simple design. Just an adapter plate between your oil filter and the filter boss on your block that has a thermostat in it that allows oil to flow through the lines to the cooler and back again.
Really only necessary if you drive the truck looong distances or tow alot in a hot environment, all it effectively does is add to the capacity of the oil system, keep oil temps lower, and extend oil change intervals by a little bit.
83burban is offline   Reply With Quote
Old 11-30-2010, 01:11 AM   #3
bhummell
bhummell's Avatar
Cool Re: factory oil cooler?
was on some 6.2 dsl from factory
on all military m1008 m1005 pickups and blazers in radiator with 6.2 dsl
1970 CHEVY MONTE CARLO NHRA/IHRA STOCKER
1976 PONTIAC GRAND PRIX ORIGINAL EXCEPT INTAKE AND CARB
1979 3/4 TON CAMPER SPEICIAL PROJECT
bhummell is offline   Reply With Quote
Old 11-30-2010, 01:24 AM   #4
79gmcc15
79gmcc15's Avatar
Ah! huh! cool! dealer option. I definitely want to keep in on my truck throughout the swap. Not going to hurt anything and thats how the truck came. You can see the lines on the lower right of pic.
RIP ELJAY
Old 11-30-2010, 08:04 AM   #5
48cj2a
48cj2a's Avatar
Yes, my Mil CUCV M1009 with 6.2 has one built in the radiator as did the 87 Crew I'm using for the donor parts.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 11-30-2010, 09:20 AM   #6
tucsonjwt
My 1983 C20 454 granny 4 spd has factory oil cooler - not a bad option for hot AZ, plus this was ordered as a camper special. It also has a stock 7 quart oil pan, so it can use the extra cooling.
tucsonjwt is offline   Reply With Quote
Old 11-30-2010, 10:01 AM   #7
b454rat
I had an 84 3/4t that was a 350, 408 when I got it, had the factory oil cooler on it. I'm sure my 89 crew has it too, but since I didn't pull the motor, not sure. Lines aren't there, but probly went with the motor.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-30-2010, 10:24 AM   #8
80SPORT
80SPORT's Avatar
Definitely available as a factory option ...RPO KC4
Popular with the trailer tow/camper units
The lines leaked after a while so they were often disconnected.
Also available as a dealer kit;a nos one sold on ebay last week
80SPORT is offline   Reply With Quote
Old 11-30-2010, 01:23 PM   #9
SBTork
Garage wrench
SBTork's Avatar
100% accurate. You can call your local parts store for oil cooler, lines, etc. They were definitely a factory option.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-30-2010, 01:35 PM   #10
83burban
Sorry for the misinformation then, thought that they were only a dealer option. I took mine out since I swapped motors and I didn't want the gunk from the old coller messing up my new motor.
Anyone know where to get replacement parts for them - I have everything just need a new cooler. Thanks
Old 10-14-2011, 10:44 PM   #11
Mr. 250r
Mr. 250r's Avatar
is this what your talking about, i have the kc4 rpo code
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-15-2011, 07:39 PM   #12
qksilver
I have a htread asking about some pix of how it is installed. Bough a factory one 2 weeks ago, my 78 came with one but was missing when I bought it.
I have the complete unit except it seems , from your pix, the brackets for the lines and cooler itself.
If possible , no hurry or anything could you post or email me some pix of how the lines are run, any brackets for them and where and how the cooler is mounted. The adapter no problem there.
Thanks,
Steve
SCJKOVACH@GMAIL.COM
qksilver is offline   Reply With Quote
Old 10-15-2011, 07:41 PM   #13
qksilver
whoops, plus are those lines for the P/S cooler? pix of those would be cool too. If I can't find one I could bend one up. I am in the process of getting and nstalling all the options my 78 came with from the factory and not there when I bought it.
Thanks again,
Steve
Old 10-16-2011, 03:27 AM   #14
juiceman650
juiceman650's Avatar
My 75 has an oil cooler that sits in front of the radiator. Can't remember if its on the SPID in the glove box, or if its something the PO added.
1975 Chevy Cheyenne w/ v8 350 and TH350
Siverado interior
Fleetside bed
aka "The Beast" aka "Cheyerado"
juiceman650 is offline   Reply With Quote
Old 10-16-2011, 09:41 AM   #15
Keith Seymore
Keith Seymore's Avatar
Agree; RPO KC4 (...I knew that one by heart).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-23-2011, 07:41 PM   #16
MNRacing
I have an 86 with the factory oil cooler option. My lines are leaking and I can't find new ones anywhere. Has anyone bought these lines and if so, where?
MNRacing is offline   Reply With Quote
Old 10-23-2011, 08:49 PM   #17
Mr. 250r
Mr. 250r's Avatar
Not sure if someone thought mine was a power steering cooler it isn't its the oil cooler, the lines go right in by the oil filter also have the kc4 option
2003 1500 Silverado
