Old 11-29-2010, 11:00 PM   #1
k5hart
k5hart's Avatar
Under dash wiring help
Could someone help me understand what these wires should be doing??
I believe the Red is going to the cig lighter, the Orange is going to the blower motor relay, and the grey is for lighting somewhere? Is something supposed to be plugged in a the fuse panel?
This is on a 1972 blazer with A/C.
Thanks!
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 11-29-2010, 11:59 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Under dash wiring help
The red wire for the cigarette lighter plugs into the fuse box in a spot labled "cig", the gray wire is for the lights in the heater controls and the extra plug coming off of it would be used for the light in the shift indicator if you had a tilt column, it plugs in a spot on the fuse box labled "clstr feed". The orange wire for the blower motor I believe plugs in the "ign unfused" spot, but I'd have to look at my truck to be positive.
ls1nova71 is offline   Reply With Quote
Old 11-30-2010, 08:26 AM   #3
k5hart
k5hart's Avatar
Thanks lsnova71. I thought that was the case on all but the Orange wire. The connector on the orange wire isn't designed to plug into the fuse panel. It can however plug into one of the connectors on the red wire. This is my biggest question actually. I'm trying to fix my hign fan speed and I am not getting power at the orange wire. Just wanted to make sure I'm right before plugging wires in randomly. If this is right my next problem will be fixing my cig lighter feed on the fuse panel. PO has burned the connector up.
Old 11-30-2010, 09:35 AM   #4
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
If that orange wire is paired with a white wire, it's likely for the dome light.
TobyArnot is offline   Reply With Quote
Old 11-30-2010, 09:40 AM   #5
70cst
70cst's Avatar
You all are good!!!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-30-2010, 09:47 AM   #6
KEL
72 GMC
KEL's Avatar
your picture looks exactly like under my dash, and I've wondered the same things. Also, I have no high speed on my fan either ! When you get it all
sorted out, will you let me know ?
KEL is offline   Reply With Quote
Old 12-01-2010, 09:32 AM   #7
k5hart
k5hart's Avatar
Orange wire is definetly going over to the blower motor relay. I don't think it's the dome wire. The grey wire may be though. I am still a little confused on what's supposed to be. The Red wire is definetly going to the cigarette lighter and the orange connector fits right into one of the red connectors. Would they have pulled power for the high speed blower from the cigarette lighter?? Seems weird to me but possible I guess.
Anyone with an original truck out there that could check this? I've been going through the assembly manual but not getting a lot of clarification there.
Old 12-01-2010, 12:44 PM   #8
k5hart
k5hart's Avatar
Based on this post I think my idea is correct. The Orange plugs into the second jumper off the Red wire which plugs into the Cig port on the fuse panel. Funny how I've missed that on the diagram everytime I looked at it. I think I didn't believe it.
http://67-72chevytrucks.com/vboard/s...ghlight=blower
I'll have to figure out how to try this out. I wish my Cig connector wasn't burned off. I'll start a new post asking how to fix that I guess.
Old 12-01-2010, 02:41 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Red wire plugs into the CIG. plug.
Gray wire plugs into CLSTR FEED plug.
Do the gray wire and orange wire run together in the harness?
If so the gray wire is for the light bulbs in the heater control, and the orange wire is the main power wire for the heater/AC. There should be a brown #10 wire that plugs into it. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-01-2010, 03:38 PM   #10
k5hart
k5hart's Avatar
Yes they do.
Maybe this is why only one light works on the heater control.
Where should the brown #10 plug in??
FYI. Heater core worked great. Thanks! This has been an adventure getting everything put back right and working.
Old 12-01-2010, 05:59 PM   #11
Classic Heartbeat
I am glad that the heater core worked out for you. I try to keep the highest quality parts here in stock and I have used that brand befor myself. The brown wire is a part of the main underdash harness. You probably will have to search it out. You might check the light bulbs in your control while you are under the dash. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
