Old 11-30-2010, 05:17 PM   #1
68 TT
Still plays with trucks
68 TT's Avatar
NP241 speedo output conversion
Has anyone changed an NP241C with the VSS output to a cable driven speedo output?
I have a cable driven NP208 and will be picking up a 90 Suburban with the NP241 as a drive train donor that has the VSS output. I need the cable drive to run the speedo as I don't want to install an electric speedo or the ECM in my truck.
Anybody done this?
I know the two share some parts and both have the same output spline count. Could it be as simple as a tail shaft housing swap?
I would just use the NP208 but it is a 27-spline and I need the 32-spline to mate up with the T-400 I am installing.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-30-2010, 05:31 PM   #2
Jonboy
Slots go on anything!
Re: NP241 speedo output conversion
I think they are very similar. The only problem you might have is if there is a driven gear pressed onto the output shaft of the transfer case.
If your 208 is in good shape, why not just run it? It "should" bolt in place of the 241.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 11-30-2010, 06:00 PM   #3
68 TT
68 TT's Avatar
The NP208 I have is 27-spline for use behind a 700R4 / T-350 so it won't bolt up to the T-400 that I want to install along with the NP241. The NP241 is stronger too so that is another reason I want to use it.
The drive gear on the NP208 just slides on over the output shaft. I would bet the reluctor ring on the NP241 is removable too.
I have a press and was a machinist for the air force so a pressed on gear is no big deal.
Hopefully the OD is similar and all I have to do is maybe drill a retainer pin notch to keep the drive gear in place.
My big concern is that the tail housings don't interchange.
Worst thing that happens is I end up having to buy a whole set of Auto Meter gauges for my truck so I can get an electronic speedo to work with the VSS output of the NP241. Honest honey, I had to buy $600 worth of gauges so my speedometer would work
