is this a true 4 bolt block?
Hey all,
![]() 76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
Re: is this a true 4 bolt block?
From the looks of it..looks like 4-bolt mains to me!
![]() Posted via Mobile Device
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
I thought the end caps had to be 4 bolt as well?
NOT REALLY BANNED!
![]() Join Date: Jul 2004
No
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
theres no room for the extra bolts on the end caps.Definately a 4 bolt
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
NOT REALLY BANNED!
It's a factory 4 bolt motor. No one would really go through the trouble to drill and tap extra holes when 4 bolt blocks are so plentiful. Front and rear caps on 4 bolt motors never had 4 bolts in them due to space constraints like previously mentioned.
#8 | |
God is good!
http://cgi.ebay.com/ebaymotors/ws/eB...d=170568672171
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
#9 | |
NOT REALLY BANNED!
#10 | |
I think what he was getting at was "people do convert them"
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
The big block motors with 4 bolt mains are 4 bolt on all caps.....this may be why the was some doubt about the small block 4 bolt units only using 2 bolts on the end caps...
God is good!
Yes, thanks. If one is starting from scratch, sure the route to take would be to find a good, strong bottom end. The reasoning behind these conversions is that some folks may already have a solid foundation/built engine that it would be cost effective to get the kit.
I do believe though, that 2 bolt blocks are severely underrated by most. You have to be running some pretty serious power to "upgrade" to a 4 bolt block.
Most of the 2 bolt vs 4 bolt argument is just hype. I would bet a punch in the gut that nobody can show one example of a block that failed because of the block in a street engine. IM talking anything under 1.5hp per cubic inch. Im not talking about thrown together junk that was severely out of balance and broke a main cap but actual block failure.
#14 | |
NOT REALLY BANNED!
#15 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Factory 4bolt mains are weaker than 2 bolt mains. We used to drag race a lot and I have broken more 4 bolts blocks than I care to mention. Ask any reputable race shop and they will tell you 2 bolts always hold up better, 4 bolts weaken the block webbing.
If you want a strong block for the street a 2 bolt will do fine. If you have a 4 bolt use it. If you want ultimate strength get a 2 bolt block and have the mains machined for splayed caps. http://www.jegs.com/i/Eagle/356/C4102S/10002/-1
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#16 | |
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#17 |
What's the casting number on the block?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#18 |
CaptKaos, how many 2-bolt blocks did you blow up drag racing? Chances are that you actually built a lot more 4-bolt blocks than 2.
Just messin' with you ![]() The width of the cap where it mates to the block is the most critical area. A 2-bolt 400 is more like a big block with wide cap bases and registers, they'll take a lot more abuse because of this configuration. I do agree, though, a 2-bolt block converted splayed mains is the best we can do short of an aftermarket block. Second best is an early block with "2482" cast into the 4-bolt caps, they're nodular rather than grey iron, much stronger. |
#19 |
LOL, well after popping a few and having 2-bolts that were identical stay together we caught on quick and stopped putting money into them, my buddies stuck with the, but I swapped over to BBC's.
#20 | |
factory cast blocks DO have flaws and weaknesses. When i have blown a 2 bolt block apart its usually been the caps that gave, the 4 bolts gave at the web. The Splayed main caps "help" the situation by leaving more meat where its needed. I have two two bolts on stands right now, both with blown main caps... in all honesty.. those of us blowing two or four bolt blocks should have learned long ago not to be so cheap and buy a stronger aftermarket block..... ![]() |
#21 | |
God is good!
#22 |
I'll find it and post it.
#23 |
Add me to the "Nothing wrong with a 2 bolt" club...
For a normally aspirated street engine, there are tons of other stuff to break first ![]()
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
#24 |
Most of the 2 bolt vs 4 bolt argument is just hype. Agreed. Probably an 010 block.
