Old 11-30-2010, 11:06 PM   #21
JW76
JW76's Avatar
Re: My 86 C10 Project
I've been reading Robnolimits suspension thread and intent to incorporate a few of his suggestions such as x bracing and boxing a few important locations on the frame and the strategic placement of weight. My fuel cell is going between the frame rails after the axle to put that weight in the ideal location. instead of a few hundred pounds hanging off the drivers side like the old saddle tank. The battery will also be relocated in a saddle box off the rear rail. I am working on a deal also to acquire a NOS cheater kit. My new engine should be 525 on motor + 250 shot of nitrous. I would also like to use a snow meth injection setup. Should be fun when combined with the new 12 bolt with 3.73s and my new TH400 with reverse shift pattern manual valve body and 2800 stall converter!
JW76 is offline   Reply With Quote
