Old 11-30-2010, 09:47 PM   #1
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Passing Smog Test
I know in the past, many Board Members have passed along tips on how to prep your Square for a smog test/inspection. I've searched the Forum with no luck. All the required components are in place. Any helpful ideas are greatly appreciated. Thank you!
78 Big10 454 is offline   Reply With Quote
Old 11-30-2010, 10:21 PM   #2
83burban
Re: Passing Smog Test
If the truck has cats: Drive it for over 30 mins before the test and drive it hard right before to ensure that it is as hot as possible. This will lower some of your exhaust gas values
Change your oil right before the test, will remove some of the carbon from the engine and reduce outputs as well
Make sure that your timing is set right, and de-tune the engine a bit by leaning out the jets just a little bit and retarding the timing (double check - not sure on this one personally)
Add some alcohol to the gas tank about a week before the test and drive it like that - will clean reduce some values as well
If your truck fails after this, then run some seafoam through the engine and repeat the steps - will help to clean it up further and might help it to pass
83burban is offline   Reply With Quote
Old 11-30-2010, 11:40 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
my truck had a hard time passing becuase of the tune. all emissions were way below value with the exception of nox... the tune has high advance and there was no way for me to adjust it, so I just waited till the truck was dead nutz cold and retook it. passed no prob. If you fail, post your readings and we can tell you what you need to do to get the #'s down to pass. As an inspector myself, you have a certian number of days for a 2nd free retake
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-01-2010, 01:13 AM   #4
78 Big10 454
78 Big10 454
Many thanks, 83burban and 87chevy. Those were the tips I was looking for.
Old 12-01-2010, 03:29 AM   #5
sixshooter798
Desert Rat
sixshooter798's Avatar
I recently passed with my 77 350/350.
As stated above, drive the crap out of it before you go in for the smog test. I replaced the spark plugs, wires, cap, and rotor before going in.
Also, make sure all of your emissions stuff is there and you have the timing and such set correctly.
I did not add alcohol to the tank, and I passed with flying colors.
sixshooter798 is offline   Reply With Quote
Old 12-01-2010, 04:18 AM   #6
78 Big10 454
78 Big10 454
That's good news sixshooter. This smog test has me so worked up, I may be drinking the alcohol to get over the pre-test jitters.
Old 12-01-2010, 05:04 AM   #7
tucsonjwt
I always change oil, air filter, breather element before going to emissions. Also, new spark plugs are cheap and worth replacing before you go through emissions. I just got 16 Champion platinum plugs on sale for $0 with rebate - I keep a couple of sets on hand since I only drive city and they get carboned up quickly - usually change them out before emissions every year.
tucsonjwt is offline   Reply With Quote
Old 12-23-2010, 09:46 PM   #8
78 Big10 454
78 Big10 454
OK, fellow Board members, today is my truck's 33 birthday and had her smogged. Due to the helpful tips that I received, I passed with flying colors. Thanks to all of you, my truck and I will have a very Merry Christmas!
Old 12-24-2010, 12:56 PM   #9
solidaxel
solidaxel's Avatar
.............. Who has Champions for that price in Tucson ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-24-2010, 12:58 PM   #10
solidaxel
solidaxel's Avatar
[Add some alcohol to the gas tank about a week before the test and drive it like that - will clean reduce some values as well
[/QUOTE]
What ratio gas to alcohol?
LS 3 4L70E
Old 12-25-2010, 03:28 AM   #11
78 Big10 454
78 Big10 454
I used STP Gas Treatment in lieu of the alcohol. Dumped three bottles down the carb and two more in a full gas tank. Really blows the bad stuff out of the engine.
