Old 11-30-2010, 09:17 PM   #1
tll74
"Junkyard Dog"
tll74's Avatar
Drop spindles or dropped control arms??
I plan to drop my 72 C-10 2 inchs in the front. A vendor is trying to sell me on the custom made 2 inch drop control arm (modified stock a arm) instead of a drop spindle. He says the you have to notch the control arm to clear a drop spindle to get the full turning radius. Anybody have any support either way to aid in my decision. Also any pics of a 67-72 C10 with only a 2 drop would be way cool. Thanks
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 11-30-2010, 09:31 PM   #2
64GMCHorsepower
Justified!
Re: Drop spindles or dropped control arms??
Well, I have 2" drop LCA's on the front of my 64 GMC with 2" drop springs....
view from front
view from side
Are they better? IDK.......they work for me for now, but I will probably be taking them of and doing a whole new front suspension.
It would probably be easier to align the front end with drop spindles, aligning mine was a PITA.
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 11-30-2010, 10:10 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by tll74 View Post
.... He says the you have to notch the control arm to clear a drop spindle to get the full turning radius...
If you run a 3" spindle and a 15x8 wheel you might have clearance issues. If your running any other combo you will not.
Personally I prefer dropped spindles. They give you an accurate amount of drop with no concern over ride change, alignment, or scrub line.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-30-2010, 10:18 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Would you mind saying who this vendor is?
I wouldn't say "notch the control arm",... is the correct wording.
You may have to trim (a small amount of grinding) to the lower control arm in the ball joint area, only if,... you are running 15" rims with more than 3.5" of backspacing.
Go drop spindles.
You have disc brakes already.
Get the "year specific" 71-72 drop spindles and you won't have to change any ball joints or tie rod ends.
Keith
Convert to disc brakes.
Old 11-30-2010, 10:25 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Or cut a coil and do an alignment
John
1999 Toyota Tacoma 4x4
Old 12-01-2010, 02:49 AM   #6
tll74
"Junkyard Dog"
tll74's Avatar
lolife99...the company is Charley's Drop Shop in Portland OR. chaleysdropshop.com. I talked with him at swap meet a couple weeks ago. He takes a used arm and raises the ball joint. Of course he promoting his product so that's why I'm asking.
N2TRUX..I will be running the stock 15x8 rally with a tire that will fill the well and have a sidewall. Not sure of the back spacing or the tire size I need. Suggestions?
64GMCHP..Thanks for the pics that truck reminds me of a 64 I had 25 years ago.
I really don't know how much drop I want. I want to lower it but by no means slam it. I also don't wanta give ride for look with in reason. I have already had my lowers powder coated so I don't favor the idea of a different arm. I really need some pics of trucks with a 2, 3, 4 inch drop.
Thanks Guys
Old 12-01-2010, 03:17 AM   #7
Mike Bradbury
Mike Bradbury's Avatar
With a 2" drop spindle and 15's you will scrape the LCA. Not by much but is will scrape off any inboard wheel weights you have installed. I have seen guys who have "shaved" the LCA down and fit it fine with out getting into the "notched" territory
The wheel wells on these trucks are so big that a little bigger wheel looks pretty good. The tire & wheel in my avatar is 245 60R18 on an 18x8 wheel and I have all kinds of clearance on my LCA with a 2" drop spindle.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 12-01-2010, 08:53 AM   #8
lolife99
lolife99's Avatar
Thanks Guys
Look here for "stance" photos. (scroll thru the pages)
http://www.earlyclassic.com/tech.asp...nce%20Photos-2
Your 15x8 ralley wheels will have a 4" backspace.
I like 255/60's up front and 275/60s when I run all four 15x8 wheels, which will require trimming.
Larger diameter rims will not. (17's, 18's, or 20's)
Charley's Drop Shop has a great reputation,... but to me his a-arms are old technology.
(or a great alternative to guys that want to keep their drum brakes)
But his arms are basically the same thing as a drop coil spring.
I still recommend drop spindles, for a 71-72 truck, for your needs.
Trim the lower a-arm and drive it!
Keith
Old 12-01-2010, 11:50 AM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Exactly. Go with the spindle. easy. straight forward. dependable.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-01-2010, 09:08 PM   #10
Mike J
vw guy & now c-10 guy
Mike J's Avatar
I always hear that you have to trim the arms - but Im running 2.5" drop spindles and 3" drop springs with stock arms and 15x7 steel wheels and didnt have to trim anything and dont rub on anything (granted I dont have inner fenderwells) so I guess it's not always the case.
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 12-01-2010, 09:15 PM   #11
lolife99
lolife99's Avatar
With 15" wheels,... it's all about the backspacing.
You can run a 15x7, 15x8, 15x10 and not rub a stock lower control arm,... as long as the wheel has approximately 3.5" of backspacing.
And with that said,... now you need to look at what's going to rub the fender lip.
Bigger diameter wheels can run more backspacing.
Keith
Old 12-02-2010, 02:32 AM   #12
tll74
"Junkyard Dog"
tll74's Avatar
Well, it looks like drop spindles it will be. Any suggestions on who has the best product?
Old 12-02-2010, 09:48 AM   #13
lolife99
lolife99's Avatar
Look at ECE, CPP, POL (Performance on Line), Belltech, or Western Chassis.
Stay away from AIM, Chassis Tech, or AirBagIt.com. (this is the same company with different names)
Get the spindle for a 71-72 truck.
They make them for 63-70, and 73-87 trucks also.
The 71-72 version will be a bolt on.
Summit Racing has free shipping, right now, and carry all the major brands.
Also look at the site supporters for there year end deals.
Keith
Old 12-02-2010, 01:24 PM   #14
SCOTI
SCOTI's Avatar
But.... they still have their $12 'handling fee'
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-03-2010, 02:43 AM   #15
tll74
"Junkyard Dog"
tll74's Avatar
Thanks to all especially lolife99 for the continued information. Drop spindles it is. Thanks again.
Old 12-03-2010, 11:23 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats true, but on anything with weight you are still at an advantage. Not so much on the lighter stuff, but its still hard to beat them on average.
As always lolife99 offers great info. Don't forget to check our Vendor Marketplace for Forum Specials before you buy.
Articles-
"Refining Sierra"
