3spd vs. 350 length
If I change from a 3 speed stick trans, to a TH350, is the drive shaft the same or what are the differences?
2% Forever!!!!!! |
![]() Join Date: Dec 1999
Re: 3spd vs. 350 length
Long as you use a 350 turbo with a 6in tailshaft it will be the same
Thank You, Tim. Is the TH350 crossmember easy to find?
2% Forever!!!!!! |
Someone on the board should be able to help you with a factory crossmember the holes are already in your frame and you can get a new rubber mount for it at NAPA
