Old 11-09-2010, 11:53 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
5.3/6.0 capabilities
What has to be done to an iron LS block in order for it to handle 700-800hp with boost? Which block is better 5.3 or 6.0 for a turbo build? Is it more cost effective to just get the LSX block from GMPP? I am planning my build for my LS swap so I can order parts while I am deployed. I want a turbo LS under the hood that will last and be powerful as hell.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 11-09-2010, 04:30 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 5.3/6.0 capabilities
the 6.0 is going to give you the extra displacement, so if your spending the money you might as well take the few extra cubes.
Probably want to go with forged pistons and a good rod (h-beams?), and stuff like upgraded rod bolts. I'm not sure at what hp rating you start to actually worry about the block itself failing.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-09-2010, 06:24 PM   #3
softballnrd27
I plan to go all forged on the rotating assy, I just want to know if I stay stock what block is better suited for my power/boost level wishes.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 11-09-2010, 10:27 PM   #4
85burb
85burb's Avatar
IF you got the money i would get the LSX block. Capable of holding 2500 HP. If you will be getting new internals and heads it would not be a hole lot more. And you can bore and stroke it all the way to 511 cubes. It also has 6 bolt heads. I think the 6.0 cylinder walls are too thin to bore out too much.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 11-10-2010, 12:52 AM   #5
Super73
Super73's Avatar
An iron block will hold that power all day long. There are many 5.7 Alum blocks well over that number in power cars. Look at guys like Harlan and a few others there. Over 1000rwhp with a stock crank and stock alum 5.7 block 6 years ago.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-10-2010, 01:16 AM   #6
silverspeed04
silverspeed04's Avatar
You should be fine with the stock block. A lot is going to depend on how much boost you want to get to that HP or higher HP with lower boost. I would say go with the 6.0, but I am biast because I enjoy the one in my daily. Just remember, too much internal combustion and it turns external.
Be safe Marine. Its suckin right now over here for everybody. Look forward to seeing this when you get back.
~MAC~
She broke my heart...So I broke her Jaw!
Project Grinder: 1972 Chevy C10 Longbed
Mistress Jade: 2005 4WD Silverado 2500 Ex Cab 6.0
Miss Daisy: 2006 Kawasaki ZX6, full Akrapovic Race Pipe, PCIII, Ignition Control, Ivans block off plates, Motion Pro Throttle kit
Seduction: 2013 Harley Street Glide
silverspeed04 is offline   Reply With Quote
Old 11-10-2010, 09:33 AM   #7
swb85
On a budget like Fred Sanford
swb85's Avatar
Like Super said, the factory LS blocks are tough as hell. In fact (if you have a good tune) the factory guts can take a beating too. We have a local guy that runs a bone stock 150k mile junkyard 5.3 in a featherweight mazda rx7. Only parts that aren't stock are the cam/pushrods/head studs & head gaskets. He runs a single turbo w/e85 and makes close to 700rwhp through a th400, big converter, 9" rear with 32x17 hoosier qtp's. Car runs 8.90's at 154mph in the quarter.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-10-2010, 09:51 AM   #8
Shon
Local is making 900+ at the wheels with iron block with a 91mm turbo.
TSP has some rotating assemblies on clearance for $1850, might be worth looking at all over 400 cubes...
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 11-10-2010, 02:10 PM   #9
softballnrd27
I just want to get it right the 1st time and since this will be my 1st high hp/forced induction motor I want to make 100% sure I am getting the right parts.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 11-11-2010, 09:38 AM   #10
ripdog28
ripdog28's Avatar
Just be careful with the power. Cage and all at that HP level. Im just under 600 and it scares the hell out of me when i hit it. Never owned anything over 325hp until this. Just dont want to see something bad happen to you after getting out of the hell hole.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-11-2010, 10:22 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^you saying that me running a 400+ hp motor on manual disc brakes is a bad idea
Old 11-11-2010, 11:44 PM   #12
softballnrd27
The truck will be "built" to handle that power before I put it in there. I am going to rebuild the front suspension and upgrade the braking and add a cage as well. I am also going to install a trailing arm rear suspension prior to the swap.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 11-30-2010, 12:34 AM   #13
209jose71
i have been wanting to turbo my truck to i was wondering the same thing about the 5.3 vs 6.0 to turbo
209jose71 is offline   Reply With Quote
Old 11-30-2010, 08:40 AM   #14
Shon
Either will work, heck the 4.8s can go fast too.
good thing about the 4.8 and 5.3s they are cheap and plentiful compared to the 6.0...I can not find a 6.0 in my area right now.....
Old 11-30-2010, 02:32 PM   #15
softballnrd27
As it stands right now I am going ot buy a 100% complete running 6.0 to put in the truck to get rid of the tired 305. I am going to buy a 6.0l longblock to use as the turbo build so I can have a running and driving truck while the motor is built. On another note, I might have found my son's project truck for us to build on until he turns 16. Gives us 6 years, and he wants it be flat black like mine!! I love that little guy!!!
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 12-01-2010, 08:57 PM   #16
68 c10 ls2
68 c10 ls2's Avatar
Just my 2 cents. 6.0 all day long unless you have big cash to buy an LSX block. I know your going to run a turbo but check out the Magneson Supercharges web site. They punch a 6.0(364ci) out to a 408ci running 10psi on 92 octane and make 950hp at the flywheel. I am running a stock 6.0 with 15psi of boost on E85 and "so far" its holding together! :-).
68 c10 ls2 is offline   Reply With Quote
