Old 11-26-2010, 11:03 PM   #276
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: 1969 Chevy Stepside Restoration/Build up
Originally Posted by mcbassin View Post
I love the new SPID sheet! It turned out great and I love how you put all the actual options on there.
Thanks, I thought that was a nice touch, it obviously didn't come with half of those when it was new!
Originally Posted by seldomseen65 View Post
Matthew; classic parts and lmc have a new clear lens now for the inside cab lite ,,check it out when you get a chance
LOL hmmm I replaced that with one from classic parts when I restored the truck? It's still like new!
Originally Posted by spike38 View Post
Very nice added touch!
Spike
Originally Posted by Pop's C-10 View Post
nice work
Thanks guys! But there is one flaw in the SPID.... someone, cough, needs to learn how to spell better!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 11-29-2010, 03:12 AM   #277
matthew20061
69' Chevy Stepside
Watch the video of it running!
-Matthew
Old 11-29-2010, 02:51 PM   #278
67C10BUB
67C10BUB's Avatar
Beautiful truck!!! I hope my swap turns out as well.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 11-29-2010, 09:24 PM   #279
DavidB
DavidB's Avatar
Nice I have a lq9 in mine and am very interested in doing the head/ intake swap. Do you know how much power difference there was over your 5.3? Do you know your compression, deck heads or not, ptv clearance? I like your solution to the throttle cable. Very clean truck I can definatly appriciate the time and money put into it.
DavidB is offline   Reply With Quote
Old 11-29-2010, 10:15 PM   #280
matthew20061
69' Chevy Stepside
I'm sure there will be a big power difference from the 5.3L! The 5.3L was probably making about 300-350 rwhp (just a guess) with the cam and such that it had. The 6.0L with L92 heads and LS3 Intake and Comp Cam should be making 460 rwhp! The heads are not decked or milled, PTV clearance is good with this cam but I have heard that some cams can have issues with PTV. I had seen this cam used in an Fbody with an LS2 and these heads so I knew I would have PTV clearance with the LQ9. The compression is probably around 10.8:1 or 11:1 depending on the head gaskets. Thanks!
-Matthew
Old 11-30-2010, 01:27 AM   #281
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
wow.....sweet build! Love the motor!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-30-2010, 09:45 AM   #282
mcbassin
Still Learning
mcbassin's Avatar
Your motor sounds great! Love the video!
Old 12-01-2010, 09:12 PM   #283
matthew20061
69' Chevy Stepside
Thanks! Your's should too!
Thanks!
-Matthew
Old 12-15-2010, 01:02 AM   #284
legendary
legendary's Avatar
great build! very nice
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 12-15-2010, 10:34 PM   #285
matthew20061
69' Chevy Stepside
Thanks!
-Matthew
Old 12-15-2010, 10:37 PM   #286
matthew20061
69' Chevy Stepside
Installed the AEM Wideband O2 Sensor into the exhaust system today, bank 1 on the drivers side exhaust pipe after the header and before the Y pipe. I haven't decided if I want to permanently mount the gauge yet so it just sits in the cup-holder. The aux output of the gauge is feeding into the EGR Sensor position on the PCM so I can log it with HP Tuners. Should work great for dialing in the tune.
-Matthew
Old 12-16-2010, 01:42 AM   #287
68GMCCustom
So are you going to monitor only one side?
Kurt -
Old 12-16-2010, 01:51 AM   #288
matthew20061
69' Chevy Stepside
Yes typically from what I've heard Cylinder #7 (band 1, drivers side) is famously the leanest cylinder so that's why I'm only monitoring that side. It's not necessary to monitor both. The factory O2's do that.
-Matthew
Old 12-16-2010, 02:33 PM   #289
68GMCCustom
Sure, I was just curious as to why it would be there instead of in the y-pipe. In my situtation...I need to know what both sides are doing. I'd love to add FAST's (or was it Innovate?) newest 4 channel system.....allowing a/f readings on every cylinder (w/8-02 sensors) with just 2 boxes linked together... and I think maybe even set alarms for specific parimeters on each channel?
Kurt -
Old 12-26-2010, 03:01 PM   #290
RCbowtie69
RCbowtie69's Avatar
sweet!!!
RCbowtie69 is offline   Reply With Quote
Old 12-28-2010, 10:26 AM   #291
matthew20061
69' Chevy Stepside
Originally Posted by RCbowtie69 View Post
sweet!!!
-Matthew
Old 12-28-2010, 01:46 PM   #292
RCbowtie69
RCbowtie69's Avatar
sounds great, u have came a long way with this build & keep up the hard work. The truck has turn out really nice, keep on truckin''
Old 01-12-2011, 05:15 AM   #293
matthew20061
69' Chevy Stepside
Well I got bored tonight and I was icing to do something with my truck. Originally earlier in my build I used CPP 2" front drop springs, the problem with them is they didn't really seem to lower my truck at all what so ever it was the exact same height basically as stock. So I still had the stock spring so I cut a coil off of them, sand blasted and painted them and these where the results. (Note I need to take out some homemade rear spring spacers on my rear 3" drop springs)
Original spring cut and installed.
The CPP Springs sitting next to the cut off parts of the original front springs.
BEFORE:
AFTER:
It's hard to see in the pictures but the truck is probably sitting about 3-4 inchs lower in the front, next I'm planning to add sway bars and drop out my lift blocks I added to the rear to level the truck with the too high front springs and the drop springs in the rear.
Front Fender to ground, 30-30.25 inchs
Rear Fender to ground, 32.25 inchs
I'm very happy with the results, tomorrow I'll get the rear lowered back down and install the CPP adjustable trac bar I've been meaning to install for ever. By the way, started the truck up today after it had been sitting for a long time outside and it fired right up and sounded awesome!
-Matthew
Old 01-13-2011, 01:22 AM   #294
67chevylongbed
67chevylongbed's Avatar
Looks great!
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 01-13-2011, 06:44 PM   #295
matthew20061
69' Chevy Stepside
Originally Posted by 67chevylongbed View Post
Looks great!
Thanks!
-Matthew
Old 01-13-2011, 06:47 PM   #296
matthew20061
69' Chevy Stepside
I continued on with the lowering project late into the night last night! Pulled out the lift blocks I had made and dropped down the back end, wow what a difference in the way the truck looks, just amazing! I also managed to finally remove the seized in trac bar/panhard bar, the bolt where it connects to the frame was fuzzed to the bar so I had to cut the bolt out of there with a sawzall what a pain.
-Matthew
Old 01-14-2011, 02:13 AM   #297
Sonicman
Sonicman's Avatar
Just finished reading your entire thread in one sitting. Man I'm inspired. I want to put a LS engine in my 69 but I know absolutely nothing about computer controlled engines or wire harnesses. Is it as complicated as it looks? Sharp truck bud!
Sonicman is offline   Reply With Quote
Old 01-14-2011, 02:38 AM   #298
matthew20061
69' Chevy Stepside
Thanks I'm glad your inspired it definitely takes some inspiration to do one of these trucks! As far as the LS motor swap its not really too hard, when I started I didn't know a ton about the computers but there is a ton of information to be found here that's how I did it basically. If you buy a pre-made custom wiring harness for the engine it will come with basic battery connections, ignition hot wire and starter wire so its a simple 3 wire hook up as they call it which makes it much easier. Depending on what LS engine you go with you will have to have the computer reprogrammed to delete the emissions, and VATS security system otherwise the engine will not run. Another thing to watch for is Cable vs Electric Throttle. So overall not as complicated as it looks but not as simple as a Carb'd 350.
-Matthew
Old 01-14-2011, 02:39 AM   #299
matthew20061
69' Chevy Stepside
Well when I restored my truck I bought a 2/4 spring drop kit from CPP, anyways I'm not sure if since I have a aluminum headed LSX motor that its much lighter than a SBC 350 or what but the front of my truck with the 2 inch front drop springs sat way too high while the rear was nice and low. This was an issue so at the time I just jammed some lift blocks under the rear springs to bring it back up. I finally decided fixed it!!!
So I found my original front springs, and cut off a loop, sand blasted and painted them and removed the lift blocks in the rear, and installed the adjustable CPP panhard bar. This is a before shot:
This is how it turned out after I cut the front springs and installed the rear CPP springs without the spacers:
Keep in mind the front tires are smaller but from the top of the wheel well to the ground its 30.25 in the front and 30.75 in the rear.
Some teaser engine pics, I absolutely can't wait for the month of May to come around so I can take the truck for a drive with the new motor!
-Matthew
Old 01-14-2011, 02:44 PM   #300
68GMCCustom
Lookin' great and I really like those GMPP LSX valve covers!
Kurt -
