Old 12-01-2010, 11:28 PM   #401
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 85 burb meets 6.0 lq4
Just plug it for now? The way I see it with mine....I'm to the point of "lets just get it going...I can always upgrade later"!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-01-2010, 11:32 PM   #402
85burb
85burb's Avatar
I want to find a block off plate with no hole in it. So i can use sensors in factory locations. Cant find them anyware.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 12-02-2010, 03:01 PM   #403
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by 85burb View Post
I have been looking for weld on collecter flanges. What do yall think of these.
http://www.mandrel-bends.com/catalog...mbly-1035.html
V-bands are nice. No gasket to fail. As long as you have clearance to install it and to tighten the bolt they are great to use.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-02-2010, 08:50 PM   #404
85burb
85burb's Avatar
The big diesels i work on use them. But at work they have gaskets with them. I have to get colleters welded on any way may as well get nice ones that wont leak as often.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-02-2010, 08:54 PM   #405
85burb
85burb's Avatar
Got my msd wires in mail today. They came with fancy wire lables and cool too to install the labels. Also got alt pig tail and oil psi sensor.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-04-2010, 04:36 PM   #406
85burb
85burb's Avatar
Found a coolant "swithc" as abc auto parts calls it. But the box says sensor so i prety sure i is the right one. Also got my egr/air block off plates in mail today.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-04-2010, 04:37 PM   #407
y5mgisi
Second Chance Program
y5mgisi's Avatar
Hope it works for you. Being as they say "switch" it could be for the idiot light dashes.
y5mgisi is offline   Reply With Quote
Old 12-04-2010, 05:02 PM   #408
85burb
85burb's Avatar
He asked if it was a gauge or not. So i think it may work. The oil psi sensor was also a swithc but it is the one for a gauge. It should work....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-05-2010, 06:58 PM   #409
85burb
85burb's Avatar
I got to install my plug wires today and man oh man i am happy. I have actually lost sleep worrieing if they would hit the headers or not. And they dont. I also test fitted the block off plates and drilled holes for fuel pump and regulater today. Not exactly how i wanted it to look but it is going to work fine i think.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-05-2010, 06:59 PM   #410
85burb
85burb's Avatar
And the pump....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-07-2010, 09:08 PM   #411
85burb
85burb's Avatar
Got my oil cooler bypass cover today. Got donated from a fellow swaper. Just need oil and coolant adapters and hose reducer so i can run steem line to my rad to put it where the factory heater hose goes. Need to find a reducer.. Think it is half inch line that the heater uses.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-07-2010, 09:52 PM   #412
justpball
justpball's Avatar
man its looking good bro!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 12-07-2010, 11:48 PM   #413
85burb
85burb's Avatar
Thanks!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-12-2010, 09:51 PM   #414
85burb
85burb's Avatar
Got mounts painted and bolted on. I forgot my tape measure so they are not in the right place yet. Just wanted to see the movment that have avalable. I do think these will work great. Sorry for crappy pictures not sure what happened.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-13-2010, 10:40 PM   #415
85burb
85burb's Avatar
Got my show quality racing steam pipe adapter. Also ordered 2 V band clamp assembles. All i need is to get off my lazy can and get my fuel system finished up and get coolant and oil psi adapters.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-14-2010, 12:35 AM   #416
68GMCCustom
thats purdee!
what/how are you using it? Is there a port on your radiator that size?
Kurt -
Old 12-14-2010, 08:09 AM   #417
48cj2a
48cj2a's Avatar
Saw a good trick on Extreme 4X4 over the weekend (2010 Episode 22 on the website) Host is putting a 6.0 in his buggy.
Because the radiator is going in the rear, he drilled and taped the thermostat housing to except the steam port.
He also did a 180 on the intake to put the throttle body and air clearner in the cab (the intake is not indexed like conventional intakes).
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 12-14-2010, 08:35 PM   #418
85burb
85burb's Avatar
Originally Posted by 68GMCCustom View Post
thats purdee!
I am using it to put the steam port to the rad heater core return on the rad. No not going to screw it in. I plan to remove most of the exposed pipe thread and slip hose over the end and put the clamp on the part with no threads. Should work tell i find nicer way.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-14-2010, 08:40 PM   #419
85burb
85burb's Avatar
I have seen that one. I think i watched it this week end. LOVE that show. Really miss the hot chick they used to have on there. What ever happend to her i wonder? She was on mythbusters a few times....made that show lot nicer to watch for a while.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-14-2010, 08:42 PM   #420
85burb
85burb's Avatar
Ordered my coolant and oil sensor adapters today. They should be here by friday they said. That means......i have everthing to swap it in but oil change stuff........YAY Also have to get fuel lines installed. Will do that over xmas week end i think. I have 4 days off for it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-15-2010, 04:00 PM   #421
kvn1011
Kvn1011
kvn1011's Avatar
cool!!
kvn1011 is offline   Reply With Quote
Old 12-15-2010, 04:19 PM   #422
68GMCCustom
You talking about Jesse?
Kurt -
Old 12-15-2010, 05:23 PM   #423
Clyde65
Clyde65's Avatar
Yea, she was a hottie for sure, I remember her being out for back surgery and then she came back and then disappeared.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-16-2010, 12:55 AM   #424
68GMCCustom
hey....any chic that can "build" your chassis for you and then load it up with a drivetrain and more is a keeper....and she was a looker to boot. She ought to have her own show!
Kurt -
Old 12-16-2010, 10:11 PM   #425
85burb
85burb's Avatar
My wife pretty much put her old truck together. She used to even do her own tuneups and breaks and such. This is her truck when i first met her. We dropped it in front a nother 1 inch and put primered 15x8 with like a 255/55 tire and in rear lowered 2 or so more but put 275/75s on 15x10s for a prostreet kind of look. I lowered that truck 3 time or so.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
