Big Red - Now its a SWB!
Re: What gears should I run?
My 01 tahoe has 5.3, 4l60e, and 3.73's it is heavier than your truck and has 32"x12.5" tires and it is a good all around gear. I've towed a 6000 lb. trailer with no problems before. When cruising down the highway at 70 MPH I'm spinning right at 2000 RPM.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread41 3/4 ton (wife's)-flatbed, fully restored to original01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
| Bookmarks |
