Old 11-29-2010, 09:49 PM   #1
shermro99
Wiper Fluid/Washer Questions
Does anyone have a diagram as to how the wiper hosing is set up from the reservoir to the wipers? ANd how it is operated? I figured that I push the knob down to make it work but I could be wrong.
I have a 1970 Chevy C10 P/U
shermro99 is offline   Reply With Quote
Old 12-01-2010, 06:50 PM   #2
travisfraughton
travisfraughton's Avatar
Re: Wiper Fluid/Washer Questions
I have a 70 c10 lwb and I push the knob for the washer fluid, twist it for the wipers.
not that the washer fluid gets too far, I need to find a way to narrow the openings and increase pressure or something, otherwise the fluid doesn't get more than halfway up my windshield unless i'm on the freeway doing 70.
I don't have a diagram tho. sorry.
1970 lwb hugger orange. 454 duel fuel cng and gasoline.
1990 Ford F-250 Lariat
2008 Mazda3
travisfraughton is offline   Reply With Quote
Old 12-01-2010, 10:32 PM   #3
grs
Can't you adjust the washer nozzles to make the fluid go up higher on the windshield?
grs is offline   Reply With Quote
Old 12-02-2010, 12:33 AM   #4
nasqar
Here kitty kitty kitty
LMC catalog sometimes has diagrams for us to buy specific parts from. These can be helpful to all parts of our rebuild.
nasqar is offline   Reply With Quote
Old 12-02-2010, 12:47 AM   #5
shermro99
Thank you for the replies. I truly appreciate it!
Old 12-03-2010, 06:23 PM   #6
nasqar
Did you find your answers?
Old 12-04-2010, 01:41 AM   #7
shermro99
Question Re: Wiper Fluid/Washer Questions
I checked the basic functions but I am thinking that maybe the pump is out. I just need to see a diagram to determine if it is located under the grill where the wiper control rod sits.
Old 12-04-2010, 02:22 AM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wiper Fluid/Washer Questions
The wiper motor and pump are under the dash. The only thing out under the cowl is the moving arms that work the wiper blades.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
