Old 12-04-2010, 11:04 AM   #1
65Guy
6 lug rear to 5lug rear swap help?
When i bought my 65 it had been converted to 5 lug disc in front and 5 lug rear. When i pulled off the rear drums i noticed that a little more than hlf the shoe was contacting to drum. In reading i guess that they are newer axles and it is unsafe. my question is on the 70ish factory 5lug trailing arm rearends are the axle tubes longer or are to backing plates longer or what is the differance. I need to fixit as cheap as possible. I dont want to buy new axles at $250. Thanks guys.
65Guy is offline   Reply With Quote
Old 12-04-2010, 11:11 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 6 lug rear to 5lug rear swap help?
The cheapest solution is to install a 71-72 rearend.
Your 65 rearend housing is the same as the 67-(early)70 6-lug housings,... which are narrower than the 71-72 housings. (1-1/2 total width narrower)
If you keep your 65 rearend,... the only solution is to buy aftermarket axles.
Some say you can put a spacer behind the backing plates to move them out.
But I don't reccomend this. (just my opinion)
Keith
Convert to disc brakes.
Old 12-04-2010, 11:15 AM   #3
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
It sounds like someone has put 71-72 axles in your housing ....which is narrower than 71-72 housings. I am only guessing though. If that is the case you gonna have to buy axles which are available through the aftermarket in five lug to fit your housing, the other option would be to put a 71-72 rearend in it , If you had some 65 axles you could have them redrilled to 5-lug and put those back in ....
ksbrktracer is offline   Reply With Quote
Old 12-04-2010, 11:15 AM   #4
ksbrktracer
TNT-MOTORSPORTS
beat me to it.......
Old 12-04-2010, 11:37 AM   #5
65Guy
so the 65 rearend is narrower? and it is not the sameas 71-72 with longer backing plates?
Old 12-04-2010, 11:41 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Correct.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-04-2010, 12:07 PM   #7
lolife99
lolife99's Avatar
so the 65 rearend is narrower? and it is not the same as 71-72 with longer backing plates?
Actually the 71-72 axle tubes and axles are longer.
If you redrill a set of stock 6-lug axles,... you will have to have the center hub also machined down to fit the 5-lug brake drums.
I would buy the aftermarket axles and be done,.. if I had your truck.
(get rid of those 40+ year old axles and install new ones with new bearings and seals)
Right now you have the gear ratio you want, and working brakes.
If you buy another rear axle,... you will have to look at everything and either re-do the brakes or swap your parts over and re-bleed them.
If all of your stuff needs to be rebuilt,... swapping to a 71-72 rearend would be the way to go. But it may need new axles, seals, bearings, etc.
I purchased a 71 rearend last year to do a quick 5-lug swap.
The axles and rear gears ended up being junk.
Just pointing out all your options,...
Keith
Old 12-04-2010, 12:38 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
If you're not afraid of running the axles that way, you could use HD drums to make up the 3/4" difference. Just another option...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-04-2010, 02:01 PM   #9
raycow
Even if you swap the deeper drums it is not a good idea to run the longer shafts in the early housing. The reason is that the machined area for the bearings isn't very long and the bearings could be contacting a part of the shaft that they were never intended to. It couldn't hurt to pull out a shaft and take a look. You will be able to see the wear mark from the bearing.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-04-2010, 05:27 PM   #10
65Guy
Thanks fo the help guys, what would i ask for at the parts store to get a hd drum?
Old 12-05-2010, 02:06 AM   #11
SCOTI
SCOTI's Avatar
C10 Suburban, 11 5/32 x 2.75" drum.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-05-2010, 02:30 AM   #12
darthwall
Im kinda in the same bind here I have a 68 and am doing the 5 lug swap problem is I cant find a 71-72 housing I have axels for a 77 I could put in but have to run spacers for the wheels to fit so its that much more stress on the axels
darthwall is offline   Reply With Quote
