1970 Chevy P/U C10
I cannot get the dome light to go on when the doors open. Is this a flaw or am I missing something? I have checked to make sure there was current going to it and I did replace the fuse....what am I missing? Does it take a specific light? Thank you! |
Re: Dome Light in Cab
Does it have pin switches in the door jam? Cheaper trucks didn't have them.
yep, check the switches on the door. they build up with rust and gunk. replaced mine and everything works like a charm.
Checked the switches on the side dorrs and they push in and bounce out beautifully. I am wondering if I put the right light in. Which one should it be?
Does the light come on when you turn it on from the headligh switch? If so then the problem is in the door switches.
72 Cheyenne Super 80 Silverado Blazer 2wd |
get an ohmes meter and check the wiring
The light does not come on when I turn the headlights on......Last time I checked the wiring, power was going to the dome light.... So maybe I just need to replace the switches??
#8 | |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
upgrading to an older model
not meaning to be a smart a$$ but is the bulb blown?
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
![]() Join Date: Mar 2010
I was looking into my dome light and couldn't get it to work either. I put the voltage meter on it and no power. Come to find out it was screwed into place with the wires clipped. Great job by PO. Maybe start with the obvious. Bulb, voltage....
1969 Chevy K20 Longbed |
Cool Truck
I never knew they were supposed to come on when you open the doors.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
![]() Join Date: Jan 2009
mine doesn't. it does not have door switches...... sounds like a good thing to add though
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
![]() Join Date: Jun 2006
Also, doesn't the light housing ground to the roof/screw hole. If you have power at the bulb and the bulb is not blown, sounds like a ground problem.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
Checked all the above and it is not working. I bought a fuze looking bulb that was in there previously but I am not sure that it correct. What sort of bulb does it take?
#15 |
Yeah how about some pictures.
#16 |
#17 |
That is called a festoon bulb. The replacement may be blown. You said that you have power to the socket, so it must be the bulb. If you replaced it with an LED bulb, you may have the polarity switched (+ hooked to -) in which case all you will have to do is turn the bulb 180*.
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
#18 |
Here are the pics of the dome light.
#19 |
Using a multimeter or test light, you should see voltage at both ends of the bulb if the bulb and fuse are good.
If you can't turn on the lamp from the headlight switch, ground the white wire at the switch connector. If the lamp lights now, the switch is suspect. If the lamp still doesn't light, you have a break in the white wire at some point. Try the same test at the door switches. The lamp should light when you ground the white wire if the wire is good. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
