Old 06-21-2003, 06:04 PM   #1
Warbones
Navel Inspector
Warbones's Avatar
Unhappy Cowl Cleaning!
I cleaned out my cowl area of the leaves and dirt. Huge pile!!! Put in some guard screens. Tried to clean out the drain holes in the cowl. Water started leaking inside the cab from under the dash somewhere. I tried to clean inside the vents inside and couldn't even get my hands inside the hole. I am assuming you have to remove the little doggie door. Anyway It was cool to be able to do something but turned out in a bad way with the leaking.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 06-21-2003, 09:53 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Did you try straightening out a wire clothes hanger and running it down at the outer edges of the cowl - and up from underneath - to clean out the clog? Maybe do this while running water in from the top - if the flooding isn't too bad!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-21-2003, 10:40 PM   #3
Warbones
Navel Inspector
Warbones's Avatar
So does the leaking mean I have severe rust issues???
WANTED 1967 IMPALA
Old 06-21-2003, 11:52 PM   #4
Gee_Emm
Are you sure the water came from up behind the dash or could it have come from the vents? If the drain holes in the cowl are clogged then the water might come out of the vents.
Gee_Emm is offline   Reply With Quote
Old 06-22-2003, 12:35 AM   #5
Warbones
Navel Inspector
Warbones's Avatar
I wish I knew. This is the first time I have cleaned drain holes and am still looking for directions on how to do them all. The water was running from behind the dash and down the floorboards. I am going to try the coat hanger and try again. I am hoping like you said it is from the vents.
WANTED 1967 IMPALA
Old 06-22-2003, 10:14 AM   #6
Gee_Emm
Don't forget to do the doors (2 drains per door) and the front fenders (front and rear) and the bed (holes at the front corners)
Old 06-22-2003, 10:39 AM   #7
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
thats why I am in need of a new cab!
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 06-22-2003, 10:50 AM   #8
Gee_Emm
Lack of proper cleaning is why everyone needs a new cab. If you just rinse the whole truck out a couple times a year it will stop this stuff from happening. This goes for new vehicles too.
Old 06-22-2003, 09:48 PM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
is it leaking in on the driver side or passenger side ...if its the passenger side .... check the seal at the base of your antenna ...mine was cracked and let water right down the kick panel and onto the carpet
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
